seeking true help
Old May 1, 2017 | 10:57 PM
toiy's Avatar
e320
seeking true help
i have a 1997 e320 and theres a clicking sound under the seat when i drive i think its connected to the batter some how
Old May 4, 2017 | 07:55 AM
toiy's Avatar
e320
Here is a picture What is his part
The noise is almost like a clicking sound the car sounds like it is a stick shift changing gears then it will drive fine then start again
Old May 4, 2017 | 10:59 AM
raymond g-'s Avatar
99 E320
use Google or other Web search engine
...you just type in the part number you have in front of you
Old May 6, 2017 | 10:55 AM
cm60k's Avatar
I think this is a hand brake adjuster,
something loose in it, you just need to little bit tighten the main spring,,
if clicks still there, will need to get other adjuster..
-;ZAYED;-
