cluster display
Old Apr 18, 2004 | 02:00 PM
thejdj's Avatar
1998 E320
cluster display
In this pic you can see two problems with the display. The left side is much dimmer, and one column of dots (pixels) is missing on the far right.
Are there bulbs that can be replaced? My guess is that one or more has gone out on the left.
The right side, I'm guessing, is a worse problem. If need be, can the module be replaced?
'98 E320
Old Apr 18, 2004 | 08:11 PM
sunq's Avatar
mine too..but mine is right side...
i just afraid how much gonna chrge for this..
Old Apr 18, 2004 | 09:51 PM
E-Klasse's Avatar
W205 C300
The dim part of the display is just a bad bulb from the back of the cluster. The missing dots are a major problem. You can get a whole cluster off of ebay and have the milage set to the same as what you have.
Old Apr 18, 2004 | 10:37 PM
carlsson9's Avatar
Mercedes W210 E280
i hear the clusters are pretty expensive..
you might as well go for those cool modded clusters from Japan..
one brand i've seen i s called moby dick and looks pretty sweet.
Old Apr 18, 2004 | 10:47 PM
Whitey's Avatar
98 W210 Advantgarde
More info needed please. What do they look like, what's so cool about them? Are you sure the Mody Dick actually replaces the LED display as well or does it just replace the dails?
Old Apr 18, 2004 | 11:18 PM
Corp DL's Avatar
C230 Kompressor Sport
As E-Klass said you have a bulb out on the left. You can buy the bulb at the dealer, will cost about $2-3 and you can replace it yourself. Look at the old thread https://mbworld.org/forums/showthrea...threadid=54917
I don't know if I posted that right, but you can do a search for "replacing bulb behind clock"
The problem on the right, I have seen on my car once or twice but cleared up on it's own??? So don't have a solution for you there other than to hope for the same.
Old Apr 18, 2004 | 11:20 PM
Corp DL's Avatar
Oh, by the way, the procedure for pulling out the instrument cluster described in that thread is accurate...I did it myself was very simple. The cluster fits into the dash with friction...like a cork in a wine bottle.
Old Apr 18, 2004 | 11:23 PM
Whitey's Avatar
98 W210 Advantgarde
I was told pulling out the cluster may stuff up the LEDs (weird)...is it really that delicate or is it pretty riskless pulling the cluster out?
Please give me strength bro's........I'm very keen to change the color of my back light......
CorpDL, you PM is full BTW.
Old Apr 19, 2004 | 01:53 AM
thejdj's Avatar
1998 E320
Thanks for the replies everyone. I'll pick up some replacement bulbs and yank that thing out.
I'm not gonna worry about the right-side problem for now.
Old Apr 19, 2004 | 12:35 PM
MBZ12's Avatar
'07 R350. '05 C230. '93 454SS Truck. '71 Chevelle SS.
I've got a 2002 E and my display sometimes doesn't fully function with all the dots in place thus making the time and shift position look funky. Not sure either why this happens. It does, however, clean itself up after a bit....but sometimes it takes much longer. It's just annoying....
Old Apr 19, 2004 | 12:44 PM
Whitey's Avatar
98 W210 Advantgarde
Just wondering, have you guys with problems ever pulled out your clusters? Could that be the reason....that's exactly what my mechanic said would happen if I pulled it out......
Old Apr 19, 2004 | 08:43 PM
carlsson9's Avatar
Mercedes W210 E280
Dave,
moby dick is like a brand that sells whole clusters for all mercs. I was reading it in a jap magazine (ok, i was just staring at the pictures!) but it comes in all different colours and LED lights..it doesn't look like its just the dials, but the whole thing.
I was wanting to change my dials to whites but i was told if the workers don't pull out the pins properly while installing the faces, it'll always rattle when you maintain a current speed.
i'll scan the stuffs for you when i have time. :P
Old Apr 19, 2004 | 10:23 PM
thejdj's Avatar
1998 E320
well it was a serious PITA to get the cluster out, I had to remove the under-dash panel and push it out from behind. But once it was out changing the bulb (or as the MB part # description calls it "rivet") was no problem. The cluster went back in nicely.
It's nice to have an evenly let display.
Old Apr 19, 2004 | 10:49 PM
Whitey's Avatar
98 W210 Advantgarde
Dave,
Dun worry Carlsson, the latest copy of Super Mercedes has a write up on the Mody Dick. I'm not sure if they make it for the pre-facelift 210. When I have the courage to take out the dash, I have an idea to create the same effect, more cheaply......thanks for looking out tho.
Old Apr 20, 2004 | 01:36 AM
E-Klasse's Avatar
W205 C300
I have had my cluster in and out more than 10 times. I have had it apart to change faces and needles. So far, no problems.
Old Apr 20, 2004 | 01:47 AM
Whitey's Avatar
98 W210 Advantgarde
Nice white dials....nice dash cover...fits perfectly OK, so I may pull it out one rainy day.......
Hey E, can you tell be what type of bulbs are in there (or better post pics of some)? Please?
Old Apr 20, 2004 | 03:51 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
clusters with more then 200 kilometer are no longer mileage programeable with stardiagnose...
I have several new W210 US spec pre model updated clusters with ///AMG faceplate...original mercedes - that can be send out with programmed mileage in case anyone is interested...
greetingz,
Old Apr 20, 2004 | 11:45 AM
carlsson9's Avatar
Mercedes W210 E280
no worries Dave..
you probably have the same issue of super mercedes as me. the write up shows a nerdy dude holding a cluster no?
They do sell the pre W210 cluster, saw it in the add, with blue dials..I'm just dying for blue bulbs on the clusters instead of the regular yellow bulbs. Anare there such bulbs?
Old Apr 20, 2004 | 01:53 PM
Whitey's Avatar
98 W210 Advantgarde
No nerd.....just a whole lot of clusters...I got the May 04 edition with the new AMG SLK on the cover (and the 4 hot SL's inside).
Old Apr 28, 2004 | 02:13 PM
MB_E430's Avatar
2007 C230 Sport
Dim Display
I had the same problem right side got so dim I couldn't read it. Then one day it it was fine and has not happened again.
Along the same line can all the lights on this display be changed to blue lights? It's a theme I've been working on. If so where can I get blue bulbs?
Thanx
Old Apr 29, 2004 | 12:00 AM
kicker's Avatar
E320 2000 w/GPS
same thing here
Got the same problem last winter, temperature gage LED missing few dashes, good thing it was still under warranty. Dealer replaced a whole cluster. Who knows few years down the road, it might happen again. If it did, I probably won't replace with OEMs anymore.
