Transmission problems
Old Jul 8, 2017 | 01:09 PM
MICHEL D's Avatar
s430 4matic/e320 4matic
Hi.
I had a transmission fluid hose problem that made the oil escape totaly or near , they MB mechanic tested it after reconnection via a bypass to see if the transmission had been affected , it does'nt slip but the oil pump makes a wisteling noise in first and second gear after everything is OK so can I use the car hoping the transmission will last : 2002 e320 4matic this is my winter car.
thank you and best regards to all.
