AC Compressor/Climate Control Issue
Old Jul 16, 2017 | 02:11 PM
jpagan77's Avatar
E320
I have a 98 E320. The AC quit cooling about a month ago. I had the AC compressor, drier, and expansion valve replaced. After the replacement, the mechanic told me that the compressor was not "cutting on". He did say that they could get the compressor to work when they "wired it directly to a battery". They assumed that the in-dash climate control was faulty. So I replaced that, but it's still not cooling. While the engine is running, I can see that the compressor clutch engages intermittently (turns for a few seconds, stops turning for a few seconds, etc.). Anyone have any suggestions as to what I should try next?
Old Jul 17, 2017 | 01:05 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
http://www.mercedesmedic.com/ac-air-...le-codes-list/
Old Jul 17, 2017 | 04:27 PM
jpagan77's Avatar
E320
Thank you for the link! I have the following codes, however, I'm not familiar with whether or not everything is within the correct parameters.
1 = 35 8 = 47 22 = 00
2 = 40 9 = 05 23 = 00
3 = 35 10 = 6.0 24 = 11.4
4 = 28 11 = 2.5 40 = 71
5 = 59 12 = 4.2 41 = 34
6 = 83 20 = 2.0 42 = 72
7 = 14 21 = 00 43 = 152
I also discovered the following codes (fault codes I believe):
Eb 1 231
Eb 1 232
Eb 1 234
Eb 1 424
Any help with any of these that look "off" and what I should try to fix/replace would be much appreciated!
Old Jul 17, 2017 | 05:45 PM
kajtek1's Avatar
You did not say at what time you took the first set of readings?
What about 2nd set?
Also clear the codes and run the system to see if anything comes back.
Old Jul 17, 2017 | 07:27 PM
jpagan77's Avatar
E320
I took both set of readings yesterday afternoon. I just went back and took a second set of readings a few minutes ago (6:20pm Central). I pulled the car out of the garage and had it running when I took the second set of readings. I live in NW Texas and it's pretty warm out right now.
I cleared out the Eb codes and they did not come back. Below are the second set of readings that I just took:
1 = 37
2 = 43
3 = 25
4 = 21
5 = 54
6 = 74
7 = 28
8 = 44
9 = 45
10 = 60
11 = 2.4
12 = 4.3
20 = 10.0
21 = 07
22 = 00
23 = 00
24 = 13.1
40 = 71
41 = 34
42 = 72
43 = 152
Old Jul 17, 2017 | 09:19 PM
kajtek1's Avatar
Looks like AC is working now, just not too efficient.
Your evaporator sensor is out of range, but do the morning readouts before starting the engine to confirm.
Only 1-8 sensors are really needed.
Old Jul 17, 2017 | 09:28 PM
jpagan77's Avatar
E320
I'll check the read out in the morning and report out the readings from 1-8. I did feel the ac cool down for about a minute earlier today, but then it went back to blowing room temp air. Thanks again for your help!
Old Jul 18, 2017 | 08:59 AM
kajtek1's Avatar
I might be out of net for couple of days, but if in the morning #5 shows way different than 1-4, you need new evaporator sensor.
Old Jul 18, 2017 | 07:29 PM
fabbrisd1's Avatar
A gaggle of MB's
If it was me - I'd order/install a evap temp sensor for $14 - China sensors so far are OK..
Amazon Amazon
