my door is too tight. Hard to close
Old Apr 23, 2004 | 10:41 PM
JohnAMG's Avatar
3 Porsche rotation
My driver side door seems too tight and requires significant force to close. It takes my wife 2-3 time to slam the door shut. It this something I can adjust at home or I need to bring it to the dealer?
John
Old Apr 23, 2004 | 11:10 PM
cobac's Avatar
2000 E320 4Matic Obsidian Black/Ash
My doors are doing that too.... My Jag has a heavy door and I'm used to pushing it lightly to close... on the W210 I have to practically slam the thing... its kind of annoying to get used to (Don't like slamming doors). I wish this car had the automatic closing assists like the S does.
Sorry I have no idea how to adjust this, I think it is normal.
Old Apr 24, 2004 | 03:08 AM
Alexbenz's Avatar
Sean's Sister--
i've seen a older E that a guy installed automatic closing assist on it and it was sweet.......
Old Apr 24, 2004 | 03:28 AM
Whitey's Avatar
98 W210 Advantgarde
The automatic closing assist on my boss' 7-series was ruined within a week of getting the car by passengers not knowing that it had it!
Old Apr 24, 2004 | 03:32 AM
Alexbenz's Avatar
Sean's Sister--
what, how?
Old Apr 24, 2004 | 03:34 AM
Whitey's Avatar
98 W210 Advantgarde
Slammed the doors.
Old Apr 24, 2004 | 03:37 AM
Alexbenz's Avatar
Sean's Sister--
damn that sucks, that's why i rather drive alone, others don't know what's up......
Old Apr 24, 2004 | 11:36 PM
mr_markski's Avatar
c220--sold now--W210
Try cracking th window a little to relieve the pressure inside. Just a thought.
Mark
Old Apr 25, 2004 | 01:14 AM
JohnAMG's Avatar
3 Porsche rotation
Well, I adjust the door per instruction from my service advisor and the door is much easier to close now!!! The only part to adjust is the latch on the pillar where the door locks onto. Got the wrench from the Autozone and it took less than 5 minutes to complete. Only 2 screws to loosen and a few minutes of tweaking, and now the door close nicely.
John
Old Apr 25, 2004 | 01:25 AM
Whitey's Avatar
98 W210 Advantgarde
Thanks for the update John. Can you please show pics of where and how you'd adjusted it?....I think it'll be good knowledge to have for the future
Old Apr 25, 2004 | 04:29 AM
Alexbenz's Avatar
Sean's Sister--
yes i second that, please give us some intructions, thanks mate
Old Apr 25, 2004 | 09:53 AM
JohnAMG's Avatar
3 Porsche rotation
Loosen top and bottom screws enough for the latch to move. If the door is too tight try moving it out slightly but not to a point the door isn't flush with the surrounding panels. The latch can also be move up and down for proper alignment of the door too. It will take a few trys to get to the right fitment. The driver for the screws is not a hex-driver. I bought a 3/8" T-40 star socket from Autozone for this job. Good luck.
http://www.benzworld.org/gallery/pic...04100108AM.jpg
John
Old Apr 25, 2004 | 10:13 AM
Whitey's Avatar
98 W210 Advantgarde
Thanx bro....if only I know where to get a torx wrench/driver.......I'm not in the US u see.....guess I'll have to leave it to my mechanic
Old May 6, 2022 | 01:05 AM
nicebowling's Avatar
w210
no need to take it to the dealer just for that, you can adjust it yourself by loosening the bolts that go through the frame of the vehicle (not the door) then move the piece of metal and retighten the bolts until they are in the correct position.
Old May 6, 2022 | 01:13 AM
davmil2002's Avatar
320e
That's what I found too. It's internal pressures because when a window/sunroof's cracked open a bit, it's normal. I suspect there's a relief valve somewhere that's failed or plugged up.
