Cruise Control issue
Old Nov 9, 2017 | 11:45 AM
Pompeykeith's Avatar
CLC 180 Kompressor Sport
Hi
I have just picked up a CLC 180 Kompressor Sport with 75k on the clock. In cruise control it keeps dropping in and out momentarily as I'm travelling along. Has anyone else had this problem?
Thanks.
Keith
Old Nov 9, 2017 | 01:23 PM
Originally Posted by Plutoe
That typically happens when the control module gets conflicting and or out of range speed sensor reports. The best you can do with out the experience and diagnostics is make sure all your tires have the same tire pressure\size-----if they are, then you have just joined the cream puff club and will make your first out of pocket repair expense.
Cheers Plutoe I'll give that a try. I'll post the outcome.
