C32 amg brake kit
i just talked t oa couple people and i;m going with the c32 brake kit on my car, 13.1 with silver calipers......... anyone do this to the w210? i heard mark cummins did something to his car but i have no clue
Would love to do the E55 one but I've been told the oem pump will not have enuf power to work the calipers - so braking will be compromized...is that true? So may need a whole new system rather than just bolting on the rotors and calipers. then again, if you went Brembo or other BBk's you'll need to do that anyway.
my rotors need replacing soon. Ooops forgot I was lookign at the SL55 kit, not E55...but either one is wayyyy out of my league and won't fit without a lot of hassle I guess....Just out of interest, how much does a pair (or 4) of C32 brakes cost over in the US?
No Problems with pad wear or stopping...with 20k on them
The Upgraded Brakes make a Huge difference! and look cool.
Josh K and SEVERAL others have the C32 AMG Brakes
on the front without any problems..cant beat it for the money!
This subject has been brought up several times
Several have said it wont work......
13.1 compared to brembo 14.1 is alright, good enough for me and they are cross- drilled, e55 don't don't cross- drilled so thats why no ones done that route....
w211 will cost a grip though and don't know if they will fit
Fronts
calipers- $759.00 ea.
rotors - $118.45 ea.
pads- $270.60 ea.
Rears
calipers- $498.70 ea.
rotors- $97.20 ea.
pads- $84.24 ea.
The risks involved in any brake system would be failure; resulting in no brakes. While I have not heard of any problems doing so, essentially the caliper would be working in reverse, as the pistons are designed to accept the rotor in a particular direction.
okay i'm getting the kit tommrorow.......
i need rotors/pads/caliper/hoses????what else?
thanks
Hoses?? May I suggest stainless steel brake lines for maintaining consisent brake pressure especially during threshold braking. Also, use a reputable racing fluid:
ATE Super Blue Racing
Motul 550/600
AP 550/600
Castrol SRF
Post some pics Alex when you've got them babies mounted.
