ESP light came on at 70mph
I would recommend you check tire pressures - and tire condition - all around as 1st step - a couple of lbs differential from the opposing side tire can cause ESP to trigger - plus your E430 runs lower profile tires to begin with which accentuates pressure/condition differential
On a side note, and likely not related, a few days later my idler pulley froze up and ate the belt. I thought I had been hearing odd noises from the belt/pulleys/water pump...something up front. Replaced both idler pulley, the belt tensioner and drive belt. Much quieter now.
