Trunk lock re-keying?
Old 01-15-2018, 02:58 PM
gpseymour's Avatar
2000 E320W 4Matic
There's an issue with my 2000 E320 4Matic I've never gotten around to taking care of: the trunk isn't keyed to the same mechanical key as the doors. If I want the trunk lock re-keyed, is this something I have to go to the dealer for? Can it even be done, or will I need to replace all 3 locks (2 doors, plus trunk) with 3 that all match an existing key?
Old 01-15-2018, 05:19 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Yes and yes, you use EPC to purchase another lock and key
Old 01-15-2018, 08:43 PM
kajtek1's Avatar
Received 1,730 Likes on 1,380 Posts
1922 Ford Model T / no OBD
If your doors have factory key, MB should deliver new trunk tumbler from their key shop in Texas.
Call dealer first to check as not knowing lock history that can be costly.
Old 01-15-2018, 10:43 PM
fabbrisd1's Avatar
Received 1,099 Likes on 805 Posts
A gaggle of MB's
Are you saying this because the rear trunk lock won't budge with your door/key - or are you saying you or prior owner had the locks on both doors replaced/changed without changing trunk key ?
I say this because it is very/very common for the rear trunk lock to "freeze up" from internal corrosion - dissimilar materials/corrosion - and persistent over 2-3 days with repetitive application of PB Blaster - working existing key in/out + pressure right/left (don't break you key) - will eventually free that bad puppy up.
gpseymour (01-16-2018)
Old 01-16-2018, 07:59 AM
gpseymour's Avatar
2000 E320W 4Matic
Thanks, I hadn't heard of this. I'll give it a try before I go for a new lock.
Old 01-16-2018, 10:08 PM
fabbrisd1's Avatar
A gaggle of MB's
Please understand from experience - be patient and persistent - over 2/3 days of repeated tries it will seem not to budge - then when you are about to give up - it will free up like nothing every happened.
Each cycle - spray lock with like PB Blaster - work key in-and-out (no turning) spray again - let sit for 30min + - then insert key and to work left/right with firm pressure (don't break key) - repeat cycle again.. and again...and again... then give it one last good spray of PB Blaster for the day ...1and let sit overnight.. start up again the following day...can take 2-3 days but heck it's been "frozen" for a good amount of time..
Check your driver's door lock while you are doing the trunk to make sure it's OK - a decent spray is good there to get the door lock working smooth as well...
gpseymour (01-17-2018)
Old 01-17-2018, 02:37 PM
kajtek1's Avatar
Procedure by fabbrisd1 is a good one, although I would question using PBlaster.
It is penetrant with aggressive chemistry, what might leave side effect. Not trying to get experience in the field - I think WD40 is much safer.
Still after they work, all the residue should be cleaned up and graphite apply.
Quick Reply: Trunk lock re-keying?
