Ac issues
Old Mar 1, 2018 | 05:34 AM
E430808's Avatar
Mercedes E430 sport
Ac issues
First of all my names mike I'm from Hawaii and I drive a 1998 Mercedes E430 sport.
love my car just can't stand the heat here in Hawaii without ac.
So my problem is my compressor has been shutting on and off for almost 2 years now!!! I know right how crazy! There's pretty much no ryhme or reason as to when it wants to work or not. Only thing I noticed is it works a lot more often at night. I've changed the evap temp sensor and just today had the coolant system evacuated and recharged to correct specs. I cleared my codes today which was eb1-231 and eb1-235 and they did not come back after clearing. I'm hopeful someone can help me cause I gave up 2 years ago trying to figure it out but now I'm back at it again.
Mahaloz/thank you in advance for any help!!!!
Old Mar 1, 2018 | 11:10 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Do the troubleshooting per A/C Air Conditioner Diagnostics with trouble codes list, Reset, Sensor Data ? MB Medic
Don't forget to follow up suggestions in comments
Old Mar 1, 2018 | 03:47 PM
Eurow's Avatar
1997 E320
AC self diag will help in this situation. ^^
Old Mar 2, 2018 | 05:54 PM
E430808's Avatar
Mercedes E430 sport
So here's the codes I got
1st is when ac was kinda cold at idle
1-87
2-80
3-84
4-84
5-82
6-109
7-06
8-80
9-35
10-6.0
11-4.0
12-3.9
20-3.2
21-42
22-00
22-32
24-13.5
40-164
41-33
42-76
43-152
2nd is driving with air at normal temp not cold or hot
1-85
2-80
3-100
4-94
5-87
6-181
7-06
8-78
9-37
10-6.0
11-3.6
12-3.4
20-3.2
21-60
22-49
23-32
24-13.5
40-164
41-32
42-76
43-152
looks like my rpm is way off especially while driving its reading 6000 rpm could that be what's shutting off the compressor?
Old Mar 2, 2018 | 05:57 PM
E430808's Avatar
Mercedes E430 sport
Also is the rpm read at the compressor? Maybe a malfunctioning sensor?
Old Mar 2, 2018 | 10:24 PM
kajtek1's Avatar
You did not follow the procedure, so no conclusion is possible.
So far I can see your Ac is not doing anything, but not knowing what temp you set on climatronic while 80F is not really high AC demand.
Old Mar 2, 2018 | 10:30 PM
E430808's Avatar
Mercedes E430 sport
i followed the procedure there are no error codes showing so I got the sensor values. I don't understand what I didn't do? Sorry if I missed anything
Old Mar 2, 2018 | 10:31 PM
E430808's Avatar
Mercedes E430 sport
my climate control was set on low
Old Mar 2, 2018 | 11:05 PM
E430808's Avatar
Mercedes E430 sport
I cleared the codes and nothing came back so there is no dtc codes showing up but the problem still persists.
Old Mar 2, 2018 | 11:17 PM
kajtek1's Avatar
Again, follow the procedure.
Start with sensor comparison on cold car.
Old Mar 2, 2018 | 11:41 PM
E430808's Avatar
Mercedes E430 sport
thank you for your input. I'm leaning toward the high rpm reading is the problem. Does anyone know if the compressor will shut off if the rpm reading is too high? While on the freeway my tach was reading 1500-1600 rpm and my ac was reading 6000 rpm which is almost redline
Old Mar 3, 2018 | 09:59 AM
kajtek1's Avatar
Hard to tell anything when you are avoiding the calibration test.
