Facelift W210 Headlamp Lenses on Pre-Facelift Car (Pics)
Old Apr 5, 2018 | 02:46 AM
johnathan1's Avatar
2001 ML320, 1998 E430
Hi there, been a member of this forum for quite some years now, but haven't been posting (at all) until now. Hopefully I can give back some useful info.
So basically, I wanted to clean up the look of my 1998 E430 (AMG Appearance) and was not liking the options. I wanted clear lenses, but with a stock-ish appearance. Anyway, I bought some new Lenses (off ebay, from China) that I thought were for a pre-facelift car, but when they arrived, were for a later model!
I took the headlights apart and noted all the differences, and decided to try to graft the lenses onto the pre-facelift housings. Here are the results. Im not quite finished yet with the driver's side light, but the passenger side is done. Thought I would show you guys what this unusual combination looks like. To my knowledge, it hasn't been done yet?
Looking forward to thoughts!
I'll have to get some better pictures during the day!
Old Apr 5, 2018 | 07:09 AM
oldsinner111's Avatar
s320
looks good,I did not know it could be done.what scares me about w210s is the cloudy lights,and front weld that holds the wheels.
Old Apr 5, 2018 | 10:50 AM
raymond g-'s Avatar
99 E320
you get a thumbs up for effort....but I must caution you on the potential results and it may not
be good. reflector based designs rely on either a faceted reflector to focus the beam or, if
the reflector is smooth, the lens uses a computer designed fluting which handles the focusing.
based solely on the photo you supplied, you may have eliminated both sources of beam
control. what you may find is that the beam will simply scatter and you will lose any useful
focus or 'throw' forward
did you have a chance to light up the assembly yet and view or measure the beam on a
wall using the basic headlight focusing guidelines yet?
Old Apr 5, 2018 | 01:47 PM
s320
do what turns you on,to many nit pickers on forums.
Old Apr 5, 2018 | 03:18 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Here's a DIY on the headlight lens replacement. Lenses are available out of Latvia last time I checked.
http://www.benzworld.org/forums/w210...l#post10898154
Old Apr 5, 2018 | 10:31 PM
AndreNY's Avatar
couple of Benzos
can you post a link where you bought the face lifted lenses
Old Apr 6, 2018 | 10:41 AM
johnathan1's Avatar
I bought the facelifted lenses on eBay, they came from China Directly. Took over a month to receive them! The quality is great however.
As for the beam focus, I had this concern as well. (I'm not a novice by any stretch) and I have seen plenty of other cars with factory clear lenses ( E46 BMW) and nothing but a reflector to focus the beam.
I have turned them on and the light seems slightly more concentrated, but overall brighter, and the cutoff is about the same. Really!
Old Apr 9, 2018 | 01:40 AM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
I concur with Raymond on this. In addition, the lenses may not meet NA DOT standards in the correct light beam direction. Some of these lens replacements used may be designed for the European markets where the headlight lenses refract the beams point in the opposite side of oncoming traffic in the opposite lane (ie. they drive in the opposite lanes vs. North America). I'd be P***ed, if I had oncoming low beams from the opposite direction blinding my road vision. These sellers of these lenses (from China or elsewhere) "may say" they are for NA use, but talk is cheap when they are half way around the world and you've got delivery of your replacements and you're gleeming cheek-to-cheek to get them installed. Just my 2 cents. Maybe I'm wrong....
Old Apr 10, 2018 | 08:11 PM
akinghorn24's Avatar
'01 E320 Lorinser S210
Kudos to you OP! Didn't know that was even possible but always felt there was a large resemblance between the headlamp covers between pre-post facelift models... I've done a similar retrofit, I've fitted prefacelift AMG headlights on my facelift model car (as well as the whole front end, so that's possible as well haha! See attached pictures of the same vehicle before and after!
Old Apr 14, 2018 | 08:20 AM
johnathan1's Avatar
You're wrong.
Old Apr 14, 2018 | 08:32 AM
johnathan1's Avatar
Here are the finished headlights installed. They look and function great. No issues at all with blinding oncoming traffic, or anything of that sort. They did have to have the adjustment corrected slightly since it changed a bit over the course of the retrofit. Also, I dont want to give anyone the wrong impression, or make it seem like this was a simple, or easy task. The facelift lenses are **NOT** by any means compatible with the pre-facelift headlight bezels. I just set out to do it, and i did. Took probably 8 hours (i lost track) of labor to complete EACH headlamp assembly. Tons of modification, and it's not for the faint of heart. (Of course MB would do this to two very similar headlights!)
As I mentioned I would post some finished pics, in the daylight. Here they are:
(Anyone know where to get some AMG Tow hook covers?? )
Modified LenseS (two now) on the pre facelift bezel
Old Apr 14, 2018 | 09:17 AM
johnathan1's Avatar
Here are a few more. They are just sitting in place here, so the panel gaps aren't perfect.
Please excuse the dirtiness, rock chips, and missing body pieces. This car is a work in progress.
Old Apr 14, 2018 | 02:50 PM
johnathan1's Avatar
Your car is simply gorgeous! That is the exact spec i would have looked for if this silver E430 hadn't fallen into my lap! Silver W210 Club!
What I would like to know is where the heck you got that parking pole! I had one on my 1987 560SEL years ago, but had never seen one on another car. I would love to buy one for the 210.
Old Apr 14, 2018 | 07:43 PM
raymond g-'s Avatar
99 E320
when you get a chance, jonathan1, can you post a picture of the beam against a wall or garage door from about 25' out? i would like to save this for my archive as a potential DIY
Old Apr 16, 2018 | 08:10 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Looked much, much better before. Even with the cloudy as **** lenses.
Panel gaps are obviously no concern of yours.
Old Apr 17, 2018 | 08:10 PM
johnathan1's Avatar
Old Apr 17, 2018 | 08:11 PM
johnathan1's Avatar
When I get a chance.
Old Apr 18, 2018 | 01:15 AM
Strigoi's Avatar
Originally Posted by johnathan1
Nothing that was put on that front end fits correctly.
Old Apr 18, 2018 | 08:54 AM
illest's Avatar
w210 AMG or S213
Those lenses look like the ones from the depo projectors, they make the car look alot newer.
Old Apr 22, 2018 | 07:29 AM
johnathan1's Avatar
That is probably true, but I just can't stand the thought of using a non-genuine or aftermarket part for such a large component. I wouldn't like my car if it had DEPO lights, (even if they were identical) I'd rather put in the hours and use a genuine headlamp assembly with some aftermarket lenses. I'm ok with this because a: it's not obvious, lol b:there aren't any other options for this particular look and c: they are made to look and function exactly as the original lenses (and they do). Or sometimes, when the aftermarket option is actually an upgrade over the OE part! I don't think these lenses will get hazy for a lot longer than the originals for some reason. I also used some UV-blocking Headlight coating/sealer on them to keep them looking new (works so well it's a little hard to believe)
Old Apr 22, 2018 | 01:50 PM
AndreNY's Avatar
couple of Benzos
can you please post a ebay link or item #
Old Apr 22, 2018 | 03:24 PM
Strigoi's Avatar
Look into some of the films. I have Lamin-X on my E63 and am 100% satisfied with their product.
I'd trust the films before some coating/sealer that you put on the lights. The film also helps to protect the lights from rocks and other things you encounter while driving. Once it's on, it's only noticeable if you're looking for it. Super easy to do a clean installation of it too.
Old Apr 22, 2018 | 03:45 PM
raymond g-'s Avatar
99 E320
the nice advantage of the laminar products (I have lamin-X also) is that they offer a little more
protection from airborns particulates, most of which are from grit impacts during driving. so it
isn't just the UV I'm concerned about. i've had mine on for about 6 yrs and have not noticed
any visual degradation in clarity yet
Old May 28, 2018 | 08:06 AM
johnathan1's Avatar
Here is a link to the eBay auction page, sold by "skfauto". Most of their items are extremellllllly cheap lol. The headlight lenses however seem to be of reasonably high quality. I'm certainly more than happy with them.
https://www.ebay.com/itm/Pair-Headli...YAAOSw2gxYoCNI
Old Jun 8, 2018 | 05:24 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
Interesting. Let us know how it works out (beam, leaks, etc). It looks like a clear xenon lens without the diffuser. As long as you keep the stock halogens, i don't see how this mod would be any worse than a yellow opaque lens, scattering light everywhere. Definitely a cheaper alternative to buying whole housings.
