ABS BAS ESP Problem Help !!
Old Apr 6, 2018 | 02:03 PM
Alix_W210's Avatar
E320
What's up guys I'm new here just wanted to see if I can get some help on my 01 Mercedes Benz E320.
​​​​​​So the problem I'm experiencing is my brakes start to pulsate by themselves randomly , usually when I'm going slow but has happend at 30 mph also. Once that happens my ABS & BAS ESP light come on. It feels like its coming from the front brakes. I'm thinking I may need new abs sensor.
Any Ideas what it can be ?
Old Apr 6, 2018 | 06:00 PM
lenobleb's Avatar
2021 GLS450
Hey,
I doubt the sensors could cause the pulsing. That is normally caused by bad rotors, brake pad, or wheel bearings.
Good luck,
Barry
Old Apr 7, 2018 | 12:13 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Put it on a diagnostic system before you start throwing money and parts at it. A failing sensor could fool the ESP into modulating the brakes because the sensor indicates the wheel is rotating too fast compared to the other wheels; if the car calculates a wheel is spinning due to lost traction, the ESP will apply the brakes for that wheel.
FWIW, the ESP in the W210 is crude compared to the W211's SBC.
Old Apr 11, 2018 | 03:16 AM
Alix_W210's Avatar
E320
Thanks for the help
Thank you guys for your feedback I will be taking my car in for a diagnostic check.
