Cleaned Intake Manifold!
If you get a hold of some product called BG or something (only dealer has it, I can't seem to find it anywhere), it's even better. Dynamic Perfomance / Best Bnz (Manhattan Beach, CA) put it in my car. The car now run much much better (the difference is VERY obvious), and I get about 20 more mile per gas tank.
You will have to reset the check engine light after all is done. Unplug the battery is the quickest way
This morning the "ENGINE CHECK" occured. After examed from dealer, they said my car needed to clean the carbon deposit in the intake valve, upper part of combustion area, fuel injectors...etc. Anyone experienced it??? How much did it cost for it??
Did they tell you that?
I had a car I picked up once that would drive great for 10 minutes and then start to stumble on acceleration. I put ONE bottle of techron in and within 5 minutes it was driving like a champ.
Redline is awesome too.
They said the intake manifold needed to clean.
Just by pouring the fuel system cleaner in the tank would not clean the throttle area and the entire intake manifold.
Curious to know if anyone here had their intake manifold cleaned before? ( every 3000mile, I add one bottle of fuel cleaning system in fuel tank)
http://www.mercedesshop.com/shopforum/index.php3?s=
There is a lot more knowledge over there. You need an answer from a tech, and there is a couple over there that can help you.
Unfortunately, the MAS on the M112 & M113 engine are very sensitive: they help to fine tune the engine very well, but tend to go kapub every 60K mile or so.
Engine Check occured this week again.
This morning replaced a new MAS control unit with $600.
They said the V6 engine's MAS failed every 2~3 years, is that true??
Just envy you guys living in the US that cars and car parts can be purchase with very reasonable prices.
