Lowering an E430
Old Jul 6, 2018 | 07:56 PM
01V8's Avatar
2012 E350 | 2001 E430 (RIP) | 1997 M3
Lowering an E430
Hi all,
I'm interested in lowering my E430 and was wondering how much I could lower it without needing modifications like camber plates or fender rolling. I don't want to slam it, just a slight drop for that OEM+ look. I'd like to keep it just to a set of shocks/springs and pads, but I'm pretty new to this so if there's something else that's necessary for these mods please let me know
As of now, I'm looking at Koni Sport shocks and H&R Sport Springs from Tire Rack. I've heard of looking for a parted-out E55 and grabbing the suspension from that, but I have no clue where to find one of those.
I appreciate any help and am looking forward to modding my car a bit.
Thanks!!
Old Jul 6, 2018 | 08:31 PM
AndreNY's Avatar
couple of Benzos
cut the springs 1 coil and change the shocks
Old Jul 7, 2018 | 01:06 AM
raymond g-'s Avatar
99 E320
based on the geometry and specs of the 210 cars a lowering of less than 1" should not result in the
need to have camber bolts installed. fender rolling generally isn't an issue unless you change the
offset of the front wheels or go with taller/wider tires. H&R sport springs, if you read the tech specs,
will result in a drop of 1.5-2" and thus, require camber adjusters.
here is a link to an old primer which may help give you a foundation of what you're about to undertake
https://mbworld.org/forums/e-class-w...right-way.html
Old Jul 8, 2018 | 11:45 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
I've got cut H&R springs (I think 2 coils removed) on my wagon right now and they lowered the car about 1.5" all around. Zero issues with rubbing and it hasn't needed an alignment. My tire wear is fine and the car doesn't pull to the sides at all.
The springs were off of my old W210 E55 and the front shocks are some Bilstein B6 ones for an E430 Sport. There's a pic of the car in my sig.
Old Jul 9, 2018 | 07:44 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
as others stated, with a drop less than 2 inches, you wont need much in the way of camber bolts/arms/etc, but i would highly recommend an alignment. Your rear tow could be barely within spec right now and a mild drop could put it out of whack. It will also save your tires.
Old Oct 24, 2019 | 04:38 AM
Taylor Larsen's Avatar
2001 w210 e430
Dropping my 01 e430
I know this is an old thread. But could anyone possibly lead me in the direction of how to get my hands on a set of spring pads? I’m running 19in AMG wheels and I’d like to bring the car down a bit.
Old Oct 24, 2019 | 12:09 PM
illest's Avatar
w210 AMG or S213
part #s for the spring pads for W210:
Front
210 321 01 84 - 5mm
210 321 02 84 - 9mm
210 321 03 84 - 13 mm
210 321 04 84 - 17 mm
210 321 05 84 - 21 mm
rear
210 325 01 84 - 5 mm
210 325 02 84 - 9 mm
210 325 03 84 - 13 mm
210 325 04 84 - 17 mm
Old Oct 24, 2019 | 03:51 PM
2001 w210 e430
Front
210 321 01 84 - 5mm
210 321 02 84 - 9mm
rear
based on the research I’ve been doing with the part numbers you’ve provided, none of these seats are compatible with my e430. Also am I stuck going thru eBay or a dealer to acquire these parts or are there other options?
Old Oct 24, 2019 | 04:22 PM
raymond g-'s Avatar
99 E320
I'm not sure why you feel the part numbers aren't suitable for your model. Are you getting different part numbers
or is some robot web part engine saying "does not fit" etc or what? These are simply hockey pucks in different
thicknesses and aren't finely engineered by engine size or car weight so (for the most part) cover all 210s.
Why not just pick a car parts vendor online and let them source the proper parts then? That way THEY can
stand behind their order if it doesn't fit your VIN
Old Oct 24, 2019 | 07:34 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Front
210 321 01 84 - 5mm
210 321 02 84 - 9mm
rear
These are the correct stock #s for w210s.
That's what I have on my bookmarks.
(These also work on our 99 w202)
Old Oct 25, 2019 | 09:35 PM
MBkid30's Avatar
1998 MB E430
My sons is lowered approx 1 1/4". With the OE 16" wheels it looks pretty good for doing it cheap. Tires are a bit wider and a lower profile. Springs are H&R.
actually I don’t think that pic had the lowering springs on it.
I do know this one does though!
Old Sep 30, 2020 | 09:55 AM
GregScheller's Avatar
'07 SL550 80m miles, '98 e430 350k miles - 02 E55 AMG 165k miles - 07 SL550 72k mile
hi illest
love the "stance" shown in your w210 photo and want to duplicate it / help me pls
My setup: 98 E430 rims 18" monoblocks from E55 / stock suspension bits
your signature line says . . . . . . . . . . . . #1F #2R pads
does that mean the first below front of 5mm and the second of 9mm ? or ?
and . . . in your opinion is the ride still good ?
and . . . Vogtland's web site says their "SPORT LOWERING SPRING" drops by 1.6" . . . sound right ?
https://www.vogtland-na.com/us/en/pr...del=832&page=1
THANKS
210 321 01 84 - 5mm
210 321 02 84 - 9mm
rear
Old Oct 2, 2020 | 10:30 AM
illest's Avatar
w210 AMG or S213
I have 5mm pads in the front and 9mm in the rear
The ride with the vogtland springs is not too bad. I live in the Washington DC area so many of the roads are not in good condition. On good roads the ride is nice. It has been years since I had the stock suspension so I can give a good comparison.
Here are some pictures before and after the springs
Before the drop. Stock suspension with #3 pads in all around
After the drop
Old Oct 19, 2020 | 03:12 AM
illest
pls forgive my late reply and THANK YOU for your assistance !
Old Oct 23, 2020 | 06:52 PM
Richard / E320's Avatar
2001 E320
This is a really old thread but for any potential future 'searches' on the subject, here is a link to my E320 height-drop.
http://www.geocities.ws/mymercedesbe...oy_wheels.html
