Engine stopped crancking
Old Jul 28, 2018 | 01:35 PM
carlos2000's Avatar
e320
1998 e320.
Went to store, parked. came back and wont crank.
Battery is topped off.
I usually hear the fuel pump turn of when turning key and then crank. but now nothing. Dash lights up normally.
I saw prior post showing a no-start issue that was the fuel pump relay. That example, the engine would crank wont no start.
My issue is it wont crank or hear any clicks.
Old Jul 28, 2018 | 06:53 PM
Newbeetomb's Avatar
CLK 320 w208
Sounds like a tumbler issue of some sorts..you have power at the dash...but hear no fuel pump prime..no “click”..as in a starter issue....and assuming the column has power to the tumbler, I’d tend to think if the tumblers not making electrical connection...I’d start there,...go to main fuses, the power cable to the starter solenoid....
Old Jul 28, 2018 | 07:33 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
How long was the car stored for? Any chance rats got in there and started chewing up some wires?
Old Jul 30, 2018 | 08:26 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
Could be a number of things, but...
One of the easiest checks on your neutral safety switch is to turn the key to on, and put the car in N, then try and start. If it cranks over, your neutral safety switch is failing and you should replace it.
basically even though the car is in P, it thinks its in D or R and wont crank.
