1998 E320 will not crank
Old Aug 5, 2018 | 05:39 PM
e320Runner's Avatar
1999 ml320
My 1998 e320 will not crank. All electrical and lights work. Battery checks out and I have tried a newer battery.
checked all fuses (engine compartment - both, under seat); all checked out.
connected obd scanner and no return codes.
will answer any questions and accept any advice.
thanks.
Old Aug 5, 2018 | 09:36 PM
e320Runner's Avatar
1999 ml320
response to Plutoe
thanks for the recommendation.
will check/replace K40\4k2 starter relay.
Old Aug 6, 2018 | 01:30 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
No crank aka the key turns, cluster lights come one, but starter will not engage?
Observe car voltage. Even with good battery you can have dirty connections.
Old Aug 7, 2018 | 02:18 PM
Jagular's Avatar
'99 E320, '65 Chrysler 300, '03 Silverado Dually, '98 Sportster,,
Same problem......no crank
Old Aug 7, 2018 | 02:32 PM
kajtek1's Avatar
WOW! What state that starter was in? Looks like electrocorrosion eat main supply cable and that's pure copper. Took lot of salt to do that.
Very extreme situation, but evidently it does happen.
Old Aug 7, 2018 | 07:57 PM
Jagular's Avatar
Originally Posted by kajtek1
WOW! What state that starter was in? Looks like electrocorrosion eat main supply cable and that's pure copper. Took lot of salt to do that. <br />Very extreme situation, but evidently it does happen.
the car ('99 E320 wagon) was parked in Nov of '17 with broken lower control arm, was started as recently as May of this year, I repaired the control arm and discovered the battery was dead ( door was left open). We assumed that it was something in the electronic modules and relays, so I enlisted the help of a MB master tech with all the correct diagnostic equipment. After thorough inspection and0 trouble shooting (2-3 hours) we narrowed it down to the starter. we removed the starter and sure enough, this is what we discovered. Always check the simplest and most obvious things first....
