where is horn wire on k 40 relay of 1999 e320 wagon?
Old Aug 15, 2018 | 09:36 AM
bobent's Avatar
1999 e320 4matic wagon
The horn does not work. The fuses on k40 tested good. Where is the output wire for the horns? What else should I test? Ground is good.
Old Aug 15, 2018 | 09:37 AM
Eurow's Avatar
1997 E320
Take and apply 12v to the horn directly while it's unplugged from the harness, verifying the unit actually works. Also, take a peak at your clock spring, mine had let go over time and that's where my issue was.
