Mercedes e200 cdi
Old Sep 3, 2018 | 03:21 PM
ascky220's Avatar
mercedes e200 cdi
Mercedes e200 cdi
Hi
I have Mercedes w210 e200cdi my ecu was burned so I got used ecu with key and ignition switch I put on the car it's start but from won't over 1000 .
some body told me that I should change setting In ecu I have mb st connect c4 but I don't know can somebody help?
thanks
Old Sep 5, 2018 | 09:24 AM
machadosl's Avatar
1999 E240, 2007 GL500, 2004 Suburban Z71, 1997 Ford Escort MK7, 1979 VW Beetle
First of all make sure your battery has more than 12.3V then, go to the quick test menu, if there is a problem it is going to appear.
If you have itens with the exclamation symbol, you cicl on it and see what is the problem, most of the time it requires an adaptation and recognition.
If you see an f or F maybe it is a fault due voltage or worn component.
