Electrical fault
Old Oct 24, 2018 | 11:16 AM
Daddycool's Avatar
W210 1997
Electrical fault
1997 W210 (Australian) front windows stop working. Can bridge out in connector to control switches (under centre console) will work for short time then stop again. Lately all windows stopped and indicators, auto door locking/unlocking, boot switch, mirrors & coolant level light light on. After about half hour & checking all fuses (all OK) all start working again. Could this be a relay or overload relay fault. If so which one and where is it? How can I test a relay without replacing it. Also have a diff pinion seal leak. Can it be replaced easily or do I need a crush spacer and pinion yoke shaft as well.
Old Oct 26, 2018 | 08:28 PM
Gavin Viney's Avatar
w210
Has the car got damp on the inside, there are earth points under the front seats.
Check with a multi-meter, a few different faults suggest this.
