NEED HELP ASAP
NEED HELP ASAP
Ok here is my problem the car runs absolutly fine when you start it up driving it does fine until it hita normal temp. After hitting normal temp. It makes a really loud kinda grinding sound but ONLY when coming to a stop and holding the brake when i start off again it goes away
i know the car has 2 bad o2 sensors and it needs a new radiator which i already ordered and will be replacing in a week but im not sure why it is doing it i have been looking everywhere and cant find out why it is doing it
(SIDE NOTE)
THE RADIATOR FAN IS HITTING THE FAN SHROUD AND CAUSEING A RUBBING SOUND THAT IS ALSO BEING FIXED WITH THE RADIATOR
Please help i know its kinda vauge what i am giving you guys but im not sure how else to describe it
(SIDE NOTE)
I have an update on the car i dont think its the brakes i think it is a sensor of some sort because i had the car out 3 times today and the last time was only 30 minutes after the second time and it did it while in park not holding the brake but when i started driveing it stopped thats why im so confused i dont know what it could be i have an idea that it may be either the mass air flow sensor is dirty because of a dirty airfilter or if it has to do with the 2 bad o2 sensors im not sure
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Can you post a video of so we can hear the sound it's making? A dirty MAF isn't going to make a noise.
Not to be too much of a dick, but the long *** run-on sentence you wrote is kind of hard to understand. The more clear and concise you can make your post the easier it is for people to try to help you.
Yeah, yeah. Blah, blah BUT.... I know.
