Hard shifting/conductor plate question
Old Apr 29, 2019 | 02:47 PM
JONESER's Avatar
1999 E320
My ‘99 e320 has recently starting shifting hard from 2nd to 3rd every once in awhile. After about a week I was driving and after a hard shift into 3rd, it went into limp mode. I pulled over, shut the car off and restarted it. It did it again. Would that be the shift solenoids or just the conductor plate? Thanks in advance
Old Apr 29, 2019 | 11:05 PM
fabbrisd1's Avatar
A gaggle of MB's
1st things 1st - check the Tranny Adapter plug fir internal leakage - and check the Transmission Control Module for contamination to get this small thing out of the way. If replacing the lug replace with Genuine MB/Mopar only - clean TCM board by pulling and flood cleaning both sides with MAF cleaner.
Once that's done - next time it happens - get a "code" - frankly a conductor plate replacement is affordable - as long as #1 has been taken care of - and that you drain/refill tranny properly with proper fluid after conductor replacement
Old May 3, 2019 | 07:17 PM
JONESER's Avatar
1999 E320
Ok, I finally had a little time to check it out. I checked the module under the hood and everything was dry.
I pulled the tranny plug and it was flooded with fluid.
Do I just clean that out real good, plug it back up and see how it works? Can the plug on the tranny side be replaced without taking everything apart?
Old May 3, 2019 | 07:41 PM
fabbrisd1's Avatar
A gaggle of MB's
Yes - replace tranny plug ... MUST be genuine Mercedes or MOPAR only... like this :
https://www.amazon.com/Mercedes-Transmission-Connector-Adapter-Genuine/dp/B00DOCVVVI/ref=sr_1_2?keywords=722.6+adapter+plug+mercedes&qid=1556926677&s=gateway&sr=8-2 https://www.amazon.com/Mercedes-Transmission-Connector-Adapter-Genuine/dp/B00DOCVVVI/ref=sr_1_2?keywords=722.6+adapter+plug+mercedes&qid=1556926677&s=gateway&sr=8-2
Please "pull out" the TCM board and see if there is fluid on the connector....
Do a YouTube search for helpful videos..
Old May 3, 2019 | 09:01 PM
JONESER's Avatar
1999 E320
Ok, I’ll order that plug. I unplugged the TCM connectors to check for fluid and they were both dry.
Thanks for the replies!
