1999 e300td ignition problem
Old Jun 9, 2019 | 09:13 PM
ferencbrown's Avatar
2003 ford ranger 3.0L gasoline
so I went to start up my 1999 e300td and the battery was fully charged but when I stuck the key in everything was as normal but I couldn't crank the car and the fuel shutoff valve solenoid did not activate either I have read posts and the closest I have gotten was there might be a bad solid state relay somewhere I have no idea of. can somebody help me defy what is wrong, why it won't start and where to look and find the problem?
also, keep in mind this car sat on a ramp for about 4-5 years and it is a turbo diesel. I may try to clean out the ignition key.
Old Jun 9, 2019 | 09:54 PM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a photo of the M-B.
Someone will be along soon to give suggestions.
Old Jun 9, 2019 | 10:51 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W210 forum...
Old Jun 10, 2019 | 11:12 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
This is diesel issue
How do you know SOV did not open? They have been known to have deteriorating wires, so checking the wires and plug would be first thing.
If the engine doesn't turn, check the K40 relay.
Old Jun 14, 2019 | 12:18 PM
response to kajtek 1
I checked the wire to the SOV and they are good and I can hear it click when I connect the yellow wire to a 12V power source and I am getting 5V at the purple wire (starter solenoid wire) at the K40
Old Jun 16, 2019 | 05:54 PM
kajtek1's Avatar
That is not explaining much. What exactly is happening? Do you observe car voltage during attempt to start?
