Transmission died - tips for doing a used trans swap needed
Old Jul 24, 2019 | 02:00 PM
Paulcomi's Avatar
2011 E550, 1999 E320
I have a lead for a used transmission with a lot less miles than my car has. I have a quick lift to get my car off the ground safely and this is not my primary car so I am not super rushed to get it done in a day so I plan to do this myself. What tips and advice before I start down this road?
Old Jul 24, 2019 | 02:33 PM
Agent-A01's Avatar
05 W211 E500, 03 C215 CL55 AMG
Dropping a trans isn't a big deal at all and can be done in a day.
Make sure you replace the rear main seal while you're there.
Old Jul 24, 2019 | 03:03 PM
Paulcomi's Avatar
That’s a good tip. I’ll remember that.
Ive installed a trans once before in a TR6 Triumoh so hopefully it’s comparable.
What about U joints?
Old Jul 24, 2019 | 04:25 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Flex discs, not u-joints. There is also a bearing and carrier in the center of the driveshaft so now would be a good time to replace the bearing and carrier. Not very expensive as long as you are already in there.
Follow this link and read up on flex disc replacement. Good tips in there that you will need to perform anyway.
https://www.pelicanparts.com/techart...Index-W210.htm
Assuming it is your E320 don't forget to disconnect the battery ground cable at the connection in front of the rear seat.
Old Jul 30, 2019 | 07:17 PM
Paulcomi's Avatar
I had a rebuilt transmission installed
I found a shop that specializes in Mercedes transmission rebuilding and supplies shops all over so cal. They cut me a break and I installed a rebuilt with new trans mount and other stuff. Runs great now.
