AC Line Location Question
Your AC lines are all on the driver side. One from the condenser on the under side to the drier and the other 2 are (1) from compressor and (1) from the drier that connects to the expansion under the plastic wiper cowl. You wont be able to see those connectors unless you dismantle the wiper. So, inspect from front to back. Inspect the condenser from the front, again be cautious not to mistake specs of road debris, dead bugs etc. If you can see the hose from the condenser from the top check the connections. You may have to remove the splash guard to see the drier connection. The compressor will show failure on the back half where the seal is and check those connections on top. Evaporator will show in the drain line on either side of the footwell or from the drain pipes underneath.
My seal failed and sprayed pretty well on the splash guard and surrounding areas.
GL
