Headlight lens replacement in 2001 E320
Old Aug 8, 2019 | 11:13 AM
dtortoise9's Avatar
2001 E320
Are halogen headlight lenses easy to replace in a 2001 E320? Don't want to polish them as I would prefer to swap them out.
Old Aug 8, 2019 | 12:09 PM
raymond g-'s Avatar
99 E320
they are relatively easy to swap out - similar in dis/assembly to all w210s.
the headlight shell is a little more involved vs pre-2000 models (taking less than 5 mins) because the 2000-02 bumper will need to be loosened or removed
the last and important note is that the 2000-02 headlight replacement lens are more challenging to find new, OE or aftermarket, and just plain expensive (96-99 about $120 aftermarket) so you may need to settle for junkyards or Ebay used
Old Aug 9, 2019 | 02:02 AM
fabbrisd1's Avatar
A gaggle of MB's
You can do amazing things on polishing... 1st step after masking off the painted trim use odor free EZ-Off oven cleaner to removed the remaining "old UV coating" which is really the layer that yellows/frosts up.. and stripping that old layer off makes polishing EZ.... polish and use a sealer and you're done
