Lorinser Rs1 wheel vibration
Old Sep 1, 2019 | 11:52 AM
Kellenw210's Avatar
W210 wagon
Hi guys! I’ve purchased some rs1 lorinser wheels for my w210 wagon and need to find out the proper lug but to put on the car. I’ve purchased a set for the spare tire as my car did not come with one and they thread in 3 turns which is not enough. Also I am getting a violent vibration front and rear. All wheels have been balanced and they were all less than 1.50 out. I’ve been doing my research and it’s all been pointing towards hub centric rings. If anyone could point me towards a store or website where I could purchase these things it would be greatly appreciated!
Old Sep 1, 2019 | 06:25 PM
raymond g-'s Avatar
99 E320
stick play dough or similar clay into the lug hole to gain bolt seat dimensions. then order them with bolt
length which allows 3/4" of the threaded shank to stick out of the back...including any spacer or hub
thickness you plan to put on. You have the wheel there with you. Why not just measure the hub
diameter yourself to be sure?
Old Sep 1, 2019 | 07:49 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
You need at least 6 more turns, or 9 mm of bolt length.
I would make it 15 mm longer.
I drive my W212 on Lorinsers, who are at least 25 yo and have no problem, but you need to be careful with bolts.
I believe they have cone seats, but I bought my used and dye test on the seats show cone or R about the same surface coverage,.
So I used the rims with R12 in the past, now I have R14 and I simply give it 20% more than recommended torque.
Coming to your situation, I would check the hub play to start with.
The rims suppose to goon hub pretty tight
Old Sep 2, 2019 | 07:26 PM
YNVDIZW124's Avatar
lots of cars
First you have to make sure if they are ball seat or conical, second you have to check if they're m12 or m14 ball seats. The should be hub centric to 66.59 if not get some hub rings.
Old Sep 2, 2019 | 08:32 PM
Kellenw210's Avatar
W210 wagon
I’m asking for the link to said hub rings. The lugs are m12 not sure on length as of yet. Messaged lorinser USA to get nearest supplier info and am waiting to hear back. I made this post to see if I could make it happen faster
Old Sep 2, 2019 | 08:59 PM
YNVDIZW124's Avatar
lots of cars
They should use 39mm lug bolts.
Old Sep 2, 2019 | 09:13 PM
Kellenw210's Avatar
W210 wagon
Okay. When I type that into google, a lugbolt comes up for a Mercedes c250/ c63/ CLK63amg lugbolt. It’s on fcp euro so I’m not really bothered with returns. What do you think?
Old Sep 2, 2019 | 09:24 PM
kajtek1's Avatar
You already have couple advises how to determinate bolt length - why not use them?
Old Sep 2, 2019 | 10:54 PM
Kellenw210's Avatar
W210 wagon
Because I still need to get the hub centric spacers before I put on the lugbolts so therefore that takes priority in locating.
