Shift knob help
Old Jul 14, 2004 | 06:51 PM
hubert's Avatar
14'G63 AMG ,1994 Mercedes E500, 2020 Range Rover HST
Shift knob help
Finnaly bought one but need help. How do i replace it is it screw on or i just pull it out. THANX
Old Jul 14, 2004 | 07:12 PM
007's Avatar
007
on the base of the shift, u have to twist the knob counterclockwise one quarter turn. then lift the shift off.
Old Jul 14, 2004 | 10:11 PM
Whitey's Avatar
98 W210 Advantgarde
Use something with a good grip, like those non-slip rubber mats some people put on their dashes. I heard a few people had problems twisting the part loose. What knob did you get Hubert? Pix?
Old Jul 14, 2004 | 11:57 PM
hubert's Avatar
Wood and leather will post pic as soon i install. Thank YOU guys
Old Jul 15, 2004 | 01:21 AM
Whitey's Avatar
98 W210 Advantgarde
BTW, before you ruin your OEM, it is the black/grey plastic ring at the base of the knob that you turn. Once loosened, it should drop off the main body of the knob. Hope this helps.
