Underdrive pulley upgrades?
Old Jul 15, 2004 | 10:23 AM
Whitey's Avatar
98 W210 Advantgarde
I replaced one of the three underdrive pulleys (the alternator one, I think) with a 15mm larger, much lighter upgrade recently. Evosport sells them as a set of three I understand and claims 7-13hp gain for a 320 (with all three replaced). I've been told the car still has to "learn" the new set up for a couple of hundred miles before it is fully effective and so far I've not experienced a big difference, except maybe a slightly smoother acceleration. Does anyone know if I should be expecting any noticeable difference with just one replaced?
Old Jul 15, 2004 | 02:44 PM
Shane C's Avatar
E320
Pulley upgrades Sweet! where can i find the belts? how much?
Old Jul 15, 2004 | 02:54 PM
Whitey's Avatar
98 W210 Advantgarde
I learnt (too late) Evosport sells all three , with belt $379 for a V6 I think....check their site.
Old Jul 15, 2004 | 03:22 PM
Whitey's Avatar
98 W210 Advantgarde
Just in case someone would like to know, Ben of Evosport (mach430) estimated that only one pulley would yield 1/3, maybe less of the 13HP gained from the 3 pc kit they sell - makes real sense. Looks like I'll be needing the other two to get a decent boost
Old Jul 15, 2004 | 03:28 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
The Pullies Work!
When I Did My Pullies I did a Dyno Before and After..The gains are there!
The Car does NOT have to relearn ...As My Dyno pull had the gains!
Old Jul 15, 2004 | 09:56 PM
Whitey's Avatar
98 W210 Advantgarde
Originally Posted by MARK CUMMINS
The Pullies Work!
Mark, I assume you did all 3, unless you didn't get it from Evo?
Old Jul 15, 2004 | 11:01 PM
Richard Galing's Avatar
W210, W220, W163, W164, C6
Yes, Evo's pullies do work...the dyno registered min. gains but quite a noticeable pull at the stoplight.
Old Jul 16, 2004 | 12:30 AM
Whitey's Avatar
98 W210 Advantgarde
Originally Posted by Richard023
.....quite a noticeable pull at the stoplight.
That's what I need :v
