Battery mfg. date
Old Oct 31, 2019 | 01:35 PM
RPB's Avatar
RPB
Battery mfg. date
Hey Guys,
I could use some help deciphering the code etched on the side of my MB battery (0EM). It reads B62FB.
I’d appreciate the help.
Thanks!
-Rob
Old Oct 31, 2019 | 07:23 PM
loden338's Avatar
2000 E430 W210
Call any MB dealer and give their parts guy your VIN. Should be able to tell you install date. Also, side or rear of battery will usually have a month/year sticker from dealer.
Old Oct 31, 2019 | 07:46 PM
RPB's Avatar
RPB
Originally Posted by Plutoe
Whats to decipher---its the part number of the battery and the strength 760 cranking amps
The code I detailed in the description mate “B62FB”.
Old Oct 31, 2019 | 07:47 PM
RPB's Avatar
RPB
Ok thanks, I will check the sides but pretty sure there was no sticker like the Interstate MTP in my other car.
No surprise the MB dealerships around here are bloody clueless.
Cheers.
Old Oct 31, 2019 | 08:05 PM
loden338's Avatar
2000 E430 W210
Try this one:;
Feldmann Imports
4901 American Boulevard West
Bloomington, MN 55437
Parts:952-837-6350
Old Oct 31, 2019 | 08:20 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
-Rob
Do you need a new battery or looking for a replacement under warranty? It's not a specific battery than can only be purchased from a dealer. You can buy the size and amp battery needed at many auto parts stores and even Walmart.
Old Oct 31, 2019 | 08:37 PM
raymond g-'s Avatar
99 E320
i wonder if the OP is simply looking for the battery mfg date ... and if so, the code may not have been the correct one to read....yet?
Old Oct 31, 2019 | 10:17 PM
RPB's Avatar
RPB
Correct! I’d like to confirm the battery mfg date based off the code etched on the top part of it. Pretty sure B62FB is the indicator; I cannot find anything else. A few of my old Bosch batteries had the code etched in a similar fashion.
I plan on taking it to AutoZone this weekend to have my battery and alternator tested.
Thanks.
Old Nov 1, 2019 | 12:59 AM
raymond g-'s Avatar
99 E320
my mildly wild guess - Feb 2006...2016
your description/code resembles one in this thread/photo
https://www.benzworld.org/threads/de...r-age.2591834/
Old Nov 1, 2019 | 02:03 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Old Nov 1, 2019 | 08:16 AM
pgsurface's Avatar
83 300D 617T(retired), 96 E300 606n/a(retired), 99 E300 606T(retired), 07 E320 BT, 14 E3504M
Look on the top of the negative post. There is usually a date stamp there.
90% of the M-B batteries I've seen since Interstate became the distributor have that stamping.
Old Nov 1, 2019 | 09:07 AM
E55 KEV's Avatar
Veteran: Air Force
Confused? Why? To what end?
Old Nov 3, 2019 | 09:05 PM
RPB's Avatar
RPB
Pretty sure the etched date is 02/06: https://mbworld.org/forums/mercedes-...y-battery.html
Too many intermittent things popping up lately. I took it over to AutoZone for testing and they said it was good although I am not a believer. The temps dropped quite a bit recently in VA which I was reminded of the other day. Now the LCD on my instrument cluster is acting up and the driver side seat controls. Checked all fuses.. I’m replacing it regardless for the peace of mind
Cheers.
Old Nov 4, 2019 | 12:03 AM
loden338's Avatar
2000 E430 W210
Cheers.
Interstate now makes the batteries for Mercedes. Check with your local dealer for a "blem" battery, MTP 49/H8. I got mine for $60. Retails for $179. Blem usually has a few scratches or may have been installed when problem was a bad alternator, etc. Interstate takes em back no questions, makes sure they are good. You dont get the warranty, but the price is right.
