2001 e430 key wont turn
Old Nov 24, 2020 | 04:26 PM
SchwarmarkE430's Avatar
2001 e430 w21
I purchased a matched EIS, ESL, ECU and key fob from ebay because my E430 kept telling me to remove the key and wouldnt turn. All the numbers on the parts matched the ones in my vehicle. The set was tested and is claimed to be ok however when I replace everything the new key operated the doors and trunk but still will not allow the ignition to turn. What am I missing? Please help
Old Nov 24, 2020 | 09:47 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
See if this thread sheds some light for your situation.
Old Nov 25, 2020 | 12:30 PM
2001 e430 w21
I thank you for the link to information regarding the key no turn issue. As I had mentioned I did go the route of purchasing from ebay an EIS,ESL,ECU and key from a donar car. All part numbers matched my existing vehicle so I thought this would be a slam dunk.
let me also add that my steering wheel is not locked and ti my knowledge hasn't locked since the rack and pinion was replaced approximately 6 months ago?? Plus I dont recall hearing the motor in the ESL turning recently but that might be me just not paying attention.
Anyway, getting the ESL out of the car was not as easy as one might think ,even with the steering not locked but I was able to get it out and put the new one in. Also installed the new ECU,EIS and while the doors all unlock and lock with the key fob I am still not able to turn the key, hear no whirl when the key is inserted with the message to remove key on the dash. Because my old key's remote functionality had not worked for some time I'd been opening and locking the doors manually. ***interesting fact I discovered is that with the new key the lock. Unlock and trunk buttons work BUT when I hit the panic button instead of hearing the factory alarm (horn) beeping I only hear click, click until I press the panic button again. Could this be indicative of another issue? Also, in trying to get the 2 wire Pigtail ( green and green/yellow) out of the EIS the pigtail broke in half . I was able to piece it back together but because the wires came out I'm not 109% sure which wire connects to which terminal post. Does anybody know what these wires are for, which one attaches where and could that be part of my issue? Any help would be greatly appreciated as I'm currently at the end of my rope! Thanks in advance.
Old Nov 25, 2020 | 12:35 PM
khomer2's Avatar
anyway, getting the ESL out of the car was not as easy as one might think ,even with the steering not locked but I was able to get it out and put the new one in. Also installed the new ECU,EIS and while the doors all unlock and lock with the key fob I am still not able to turn the key, hear no whirl when the key is inserted with the message to remove key on the dash. Because my old key's remote functionality had not worked for some time I'd been opening and licking the doors manually. ***interesting fact I discovered is that with the new key the lock. Unlock and trunk buttons work BUT when I hit the panic button instead of hearing the factory alarm (horn) beeping I only hear click, click until I press the panic button again. Could this be indicative of another issue? Also, in trying to get the 2 wire Pigtail ( green and green/yellow) out of the EIS the pigtail broke in half . I was able to piece it back together but because the wires came out I'm not 109% sure which wire connects to which terminal post. Does anybody know what these wires are for and could that be part of my issue? Any help would be greatly appreciated as I'm currently at the end of my rope! Thanks in advance.
I would suggest you head over the BW forum and post your issue on the w210 forum. The good knowledgeable members of DAS, mrboca, Deplore, over there should be able to assist you.
