W210 Cubby - Compartment
Old Aug 25, 2004 | 01:00 PM
chan168's Avatar
97 Black E420 W210
Hi. I have an analog phone on my 97 E420. I want to remove it, but I would have a empty slot on the console. I asked some people on the forums and they said that I could go to the dealer and put a "cubby". Went there this morning and they quote me part # 210-689-03-31 for $6.60 (I was surprised it is so cheap). Is this the right part? Is it plug and play. Just slid it in?
The storage compartment that I am looking for is the one between the radio and ashtray. Thanks.
Old Aug 25, 2004 | 03:32 PM
mbmiller's Avatar
E320
I changed my analog phone unit out for a 'cubby' unit I bought off ebay for about $30. It was all inclusive plastic cubby, burlwood cover and sleeve, etc. The analog phone control unit will slip out of your burlwood sleeve piece. There is a clip on the back side of the unit that releases the phone caller id/button piece out as well as the small 2x2 cubby beside it. I pulled my stereo unit (you'll need a stereo removal tool or remove the ash tray piece, check other threads on this) out far enough for me to reach behind the analog unit and push on the tab or clip to release both the caller id/buttons and the small cubby.
The cubby piece you are looking for is just a piece of plastic, so I could see that piece being cheap. I replaced my unit before I realized that I probably could of replaced just the plastic cubby portion. So after all this long reply, the answer is 'Yes', that sounds about right for that piece. And it is easy to plug and play it.
Old Aug 25, 2004 | 05:02 PM
chan168's Avatar
97 Black E420 W210
mbmiller, thanks for the reply. I purchased the removal tool from eBay and it was quite easy to remove the radio and pop out the telephone module.
Can't find anybody to buy the cubby from? I thought the dealer would sell it too. I guess I can live with the plastic cover for now. I just need the storage space.
Old Aug 25, 2004 | 06:08 PM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
I have a birdseye one which came out when Mbenznl did my comand
Old Aug 26, 2004 | 09:38 AM
SmokeSilver's Avatar
1997 E420
Cubby install
I also have a '97 E420. I had mine taken out by the dealer at no charge and they then installed the cubby as they "Had a stack of them in the back". The dealer I use is an MB authorized service shop but not for new MB sales. I stood there and watched the guy de-install the phone stuff and install the cubby...it took him about 3 minutes.
You might want to call around to some MB shops in your area and see if they have a used one.
Good Luck!
Old Aug 26, 2004 | 11:20 AM
raymond g-'s Avatar
99 E320
Which gets me to thinking....wonder if there would be such a stack at a sound system installer which the local Benz dealer refers people to? Worth a try.
Old Aug 26, 2004 | 01:04 PM
chan168's Avatar
97 Black E420 W210
SmokeSilver, do you happened to have the part #? The one I got is not the right one. I had to return it.
Stemags, the one you got is it 210-680-16-52 "Spectacle Shelf "Bird's Eye Maple". Avantgarde"
Old Aug 26, 2004 | 05:13 PM
Neicey59's Avatar
2007 E350/2001 SLK320
I have the burl walnut slot and cover from my COMAND install as well.
Old Aug 29, 2004 | 02:27 PM
stemags's Avatar
Hey Chan,Im not sure of the part #,but its the entire spectacle shelf,if thats what you call it,and it is black birdseye maple.Has the cover,and the shelf,one piece.I have put sunglasses in there
Old Sep 6, 2007 | 10:44 AM
peterp1212's Avatar
1998 E300 TD
dash cubby
So did anyone find the correct p/n? I can not find the cubby anywhere and the MB dealer has the complete unit cubby slide and cover for ~ $150. I too took my analog radio out and am looking for fill the hole with some usefull space!
Old Sep 15, 2007 | 08:27 PM
azurE430's Avatar
1998 E430
how can I safely recycle my old phone from the dash?
