Radio knob volume UP work intermittently
Old Dec 24, 2020 | 12:01 AM
ATL_E55's Avatar
W210 E55
I have had this annoying problem since I bought the car. Volume down works fine but volume up works randomly. Most of the times the volume UP (clockwise) turns the volume DOWN.
I have tested the entire knob with the soft little clicks you can feel. Roughly about 75% or more of the clicks or adjustments turn the volume down instead of up.
I have tried electrical contact cleaner numerous times and some compressed air but not much luck with it. It appears to help briefly but if i let the car sit for a few hours, the cleaner dries up and it starts misbehaving again.
Is my bose radio unit completely trashed?
Old Dec 24, 2020 | 04:00 AM
davmil2002's Avatar
320e
Mine's sorta random too. Mostly it goes quiet on its own. It's old so I just live with it.
Old Dec 24, 2020 | 08:55 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
I had the same issue repaired by Becker Auto Sound LLC in New Jersey. Factory authorized repair center. I had them add the optional Bluetooth music streaming (bypasses cassette player but I no longer use cassettes). I prefer that my car look stock rather than have a flashy add-on stereo.
Old Dec 24, 2020 | 01:49 PM
190Efan's Avatar
1991 190E 2.3
The Becker option isn't cheap having gone this route on a new antenna for my W201 but it's probably the best option as installing aftermarket can cause a long additional list of issues.
Old Dec 24, 2020 | 11:33 PM
ATL_E55's Avatar
W210 E55
Is there an aftermarket head unit that will work with Bose amp and steering wheel controls?
Old Dec 29, 2020 | 10:09 PM
ATL_E55's Avatar
W210 E55
Checked Becker out.. They charge a flat $195 fee from what others have said.
Other options:
-Buy unit off of eBay and pray it works but radio code will change
-Buy a compatible encoder for like $15 and see if I can replace damaged encoder on the board.
-Buy a aftermarket unit that's compatible with Bose amp and steering wheel controls
