2000 E320 / Cracked "case" for Xeon's... can it be replaced?
2000 E320 4Matic Obsidian Black/Ash
As luck would have it... apparently the former owner of my 2000 E320 must have banged into something with the front headlight. The "grey" plastic case that holds the lamps to the bumper/radiator support is cracked in one spot. The light stays in the car, but it's fairly loose and inset a bit. I never noticed it until the other day when i was cleaning the bumper area...
There is nothing at all wrong with the light other than the grey plastic housing being cracked, unfortunately. I doubt MB sells this part individually and I don't want to spend $800 on a new unit when the Xeons are fine. Do you think I could get a used "non Xeon" light off ebay and use the same case over, just putting the Xeon parts into it?? Any ideas, suggestions??
Thanks,
Andrew
Thanks,
Andrew
209/W210 Estate /W211 modded by MBENZNL
Thanks,
Andrew
Thanks,
Andrew
Yes You Can Get another Headlight HOUSING and change over the parts
You WILL Need a Heat gun to help remove the lens..If You Get a NON Xeon Housing you WILL have to drill some holes for the Ignitor/Wires
Use LOTS of sealer to reinstall the lens to avoid any leaks
If No Luck on Ebay Try Steve for a Housing @www.mbenz.nl
S, GL, Escalade ESV, my shoes
No. I think they're shape differently, a bit.
Originally Posted by michakaveli
Is it also possible to gut the reflector and lense from a MY00+ and install them into a MY96-99?
Thank you Mark I appreciate the info.
Think I might have a look at some of the junk yards for a replacement (perhaps without the other bits in the back) to see if I can just replace the thing without having to glue the lenses in (sounds like a PITA)...
Former Vendor of MBWorld
some slow@$$diesels
greetingz,
