W210 Transmission Problem
Hello MB World
am a new user. I have a Mercedes Benz w210 E320 1997. About a year or so, the coolant and Transmission oil mixed and Water got into the Transmission. I send it to a guy and he fixed it. It worked about 70%. But now the car is having struggles to shift from 1st gear to 2nd gear it goes revv up to 3,500 rpms, unless I shift down to the 2nd gear with the Shifter. And the shift between the 2nd and 3rd gear there's a gap of empty ( the gear shift to 3rd but it revvs also high revvs depending on the force I apply on the Gas paddle)
any help please. The transmission costs 750$. Some told me it's a conductor plate and some told me it needs to be rebuilt again.
This is the Shifter. And the Transmission Number
And obvious "this guy" was not qualified.
Working 70% of the time is not = to 100% of the time.
Damage is done, imo, and the issue is still present.
Do yourself a favor and post your saved codes here.
You need to flush out all the fluid from the transmission. There's a possibility of permanent damage.
Both fluids will need to be changed
Verify your radiator is good.
Visited site below and followed their recommendations. Good luck with your car.
https://mercedessource.com/problems/...fting-problems
