Transmission Problem
When cold I do feel a 1st gear shift flare, like it holds 1st a little longer, a little but goes away when warmed up. I was told this is natural . Also though I am doing my flex discs and center support while there in the next few days since it might have a little to do with the flare. Plus I see cracks.
This is a plastic and fragile part, not expensive at all to buy from your local dealer.
When car and transmission is cold it holds the 1st gear a bit longer to faster heat up cats.
Make sure you are up to level with tranny oil otherwise it could make strange shiftings.
When you drain the old oil make sure you flush with new oil to suck out the old, when it's all bright red and looking fresh then you're good.
I would see if you have a auto lift rental place where you live, makes life so much easier.
