Problem with car
Old Sep 23, 2004 | 08:24 AM
carlsson9's Avatar
Mercedes W210 E280
Problem with car
Hey guys, just wanting to share a prob. with the car and hope there's someone that can help me out..
my rev is pretty odd now..feels like i'm stuck in third gear, and it won't go up into fourth..worse, when i slow down, the rev will drop down quickly below 5K, and quickly pop up to above 10K..when this happens , the car feels like its surging foward..when i set the car in neutral, and rev the engine, it does the same thing which i just mentioned, and worse when it goes below 5K and kills the engine totally..I'm thinking maybe my air flow meter is screwed, or worse still my exhaust is busted, or my gear box screwed..anyone can help chip in? thanks!
Old Sep 23, 2004 | 10:22 PM
mercedeslover's Avatar
2003 e320
I am going through something very similar. My car is curretly in the sho p because I thought it was the transmission but it turned out to be bad coils, bad suppressors and the oilers were leaking so plugs got fouled and something happened to ruin the MAF. It should be ready tomorrow and I will give you an update.
Old Sep 24, 2004 | 02:54 AM
Alexbenz's Avatar
Sean's Sister--
hard to say, take it in for a check-up soon as you can
Old Sep 25, 2004 | 08:16 AM
carlsson9's Avatar
Mercedes W210 E280
well, got the car back..it was the MAF..changed a new one at about US 420...:/ and it was a BOsch OEM MAF and not the original Mercedes parts, which would have cost me a bomb. :/
also found out that my tensioner and fan belt went kaput after only 25,000km..:/ and that was the part that was giving me problems, with a loud noise during D and R...apparently the parts i had before were OEM parts..now I've replaced it with original mercedes parts..it drives like new, but hopefully, lets see what happens after the first 5000km..
and all four of my tyres seems to be eating in the inside..:/ apparently I was told it's a W210 probelm, but I've never seen ppl raise this issue before..:/ and being directional, its a hassle to rotate, and align the tyres...
feeling pretty down with the $$ spent..time to put the exhaust at the back berner..:P
Old Sep 25, 2004 | 10:01 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Don't quite understand about OEM and original Mercedes parts. OEM parts are the original mfg original equipment and are the same as Mercedes original parts. Can you please explain what you mean??
Old Sep 25, 2004 | 11:40 AM
carlsson9's Avatar
Mercedes W210 E280
well, oem is the original parts for sure, but they're branded as the mannufacturer's parts, and not as mercedes benz ( altough they do share the same part numbers ) Although the OEM manufacturer's do manufacture parts for mercedes benz, MB has their own quality control checks before it's stuffed in their MB boxes....
for example, like the AMF, which cost me US450 for a bosch box sensor, but it will cost about US900-US1000 for te original part..
Old Sep 25, 2004 | 11:42 AM
carlsson9's Avatar
Mercedes W210 E280
its the same parts..but for my case, it seems the OEM parts doesn't seem to fit as well as the original Mercedes box parts..
but we'll see after 5000km, and see how long the belt tensioner will last..
Old Sep 25, 2004 | 04:56 PM
Richard Galing's Avatar
W210, W220, W163, W164, C6
Sounds like ur back in bizness, Karlson
Old Sep 25, 2004 | 08:52 PM
carlsson9's Avatar
Mercedes W210 E280
Thanks Rich..
back after a long time..it was sure troublesome to get the tensioner and fan belt to be fixed..I think I'll be going back to C&C for regular service, and if there's anything major and I get the actual cause of it plus the parts needed to be changed, I'll pop over to my current mechaninc due to the cheaper parts and labour..
car feels tighter now that's for sure..but my future mods are now pushed back a bit.:/
Old Sep 26, 2004 | 06:09 AM
Whitey's Avatar
98 W210 Advantgarde
Originally Posted by carlsson9
Thanks Rich..
Keeping the guys at Sunway in business, I bet.....???
Old Sep 26, 2004 | 08:00 AM
carlsson9's Avatar
Mercedes W210 E280
haha..indeed whitey....
Old Sep 26, 2004 | 10:06 AM
Whitey's Avatar
98 W210 Advantgarde
I just hope they do a better job with your Benz than what their neighbors have done architecturally......gheya$$ lion!!!!
Old Sep 28, 2004 | 12:42 PM
carlsson9's Avatar
Mercedes W210 E280
Hahhaa..i see you've taken a nice pic of the Sunway Pyramid Lion.. yeppers, I hang out there more often than I prefer, since one of my client is actually Sunway Group..Most of the car modification shops are at Sunway..more so for Japanese cars...
pity we didn't hook up...
Old Sep 29, 2004 | 11:11 AM
Whitey's Avatar
98 W210 Advantgarde
Will probably be hanging in that neighborhood very soon, PM me your phone or an email you actually read if you like....
