Persistent annoying squeak in the console
Old Feb 1, 2022 | 02:43 AM
clubted's Avatar
GLE350, C300, CLK55AMG
Hi, Anyone have this problem? My recently new to me E430 Sport has a consistent high pitched squeak my tech says is around the shifter. It even sqeaks on mild highway ripples much less on rougher roads. Trying to avoid tearing everything apart and hoping the smaller panel directly under the shift knob is removable and gives access to the problem. Thanks.
Old Feb 7, 2022 | 09:01 PM
clubted's Avatar
Persistent squeak
Thanks for the tip, I'll pass that along.
Old Feb 15, 2022 | 02:53 AM
clubted's Avatar
Squeeky shifter rattle solution?
Mechanic called me today and explained what's going on. Turns out the car needs the shifter mechanism replaced for $1200, yikes. Parts supplier they use apparently has quite a few of them available as this is a common problem with these. Does this sound right for a 2000 E430 Sport with 53k miles and one California owner prior to me?
Old Feb 18, 2022 | 03:01 AM
clubted's Avatar
Transmission shifter squeak fixed
Thanks for the tip, the bushing was missing. Not cheap to fix but what a difference.
Old Feb 18, 2022 | 12:58 PM
MattCordell's Avatar
C43 AMG with a tune up
Rubber bushing did it dry rot and fell out of place?
I assume it was the green hollow donut rubber bushing in the linkage?
Old Feb 19, 2022 | 02:30 AM
clubted's Avatar
Missing shifter bushing
They didn't tell me, only that it was missing. The clue other than the consistent high pitched rattle was that the shifter noticeably moved in left hand turns. Unfortunately expensive but drives so well now, love this thing.
