changing springs...
Old Sep 29, 2004 | 02:23 AM
808-E-320's Avatar
changing springs...
did anyone change their springs by themselves??
I have a set of H&R drop springs that im gonna install myself and im wondering if its gonna be difficult, and wondering what tools will i need...
thanks
Old Sep 29, 2004 | 02:52 AM
tpliquid's Avatar
too poor now
thanks
i did
u need spring compressor for front
for rear u need 2 jack stands, 2 jacks 19mm, 18mm, 17mm ratchet and cresent wrench.
ur all set shuold take no more then 25-30 min to do the rear
fronts take abuot 10 minuets with spring ocmpressor.
rear u dont need spring compressor
Old Sep 29, 2004 | 05:59 AM
808-E-320's Avatar
is this for a W210 cuz in your sig it says C220
sorry if they both are the same..
but anyways was it hard to do?...
Old Sep 29, 2004 | 11:22 AM
Shane C's Avatar
E320
i did the front and rear without spring compressor took me all day! i would have gladly paid $150.00 for the job! but then again i ran into some problems getting the control arm to lower. after the control arm lowered i still had to cut the old spring to remove it. if you can find a spring compressor the whole job shouldnt take more than 1/2 hour on a lift or 1 hr with a jack.
Old Sep 29, 2004 | 11:56 PM
808-E-320's Avatar
thanks
Old Sep 30, 2004 | 02:05 AM
tpliquid's Avatar
too poor now
yes they are both the same. E class is much easier since it is longer in hte back gives you more room to work with than a C class
Old Sep 30, 2004 | 01:53 PM
rob_fed's Avatar
W204 C300 2010
For the front - instead of removing the lower control arm pivot bolts, I broke or unpressed the upper ball joint. This allows the lower control arm to swing lower to remove the spring. You will still need a spring compressor to get it out, but at this point, you can use a single, external type compressor. Also, you are not compressing the spring fully, just enough to get it out of the lower spring pocket.
For the rear - I took out the pivot bolt on the lower arm. The right side went very fast to remove and replace. The left side I had a hard time lining up the mounting holes.
