W210 Wagon Suspension Rabbit Hole
Old Apr 19, 2022 | 05:37 PM
Overheated's Avatar
1998 E320 Wagon, 2003 W211 E500, 2003 W211 E500, 1999 W210 E55 AMG
Rebuilding the rear suspension on Boo's '98 E320 wagon. Ordered the "Control Arm Kit". Paid for the kit. The kit arrived. The 'Camber Strut' doesn't fit. It's different. Nobody knows anything.
On my part # A210 352 1005. MB says discontinued, then the trail leads to part#210 350 3406, which ain't the part. Then the trail goes cold. There appears to be different part numbers between sedan and wagon.
I'll be happy if I could replace the bushings only, but fitting them is a crapshoot.
Anyone experience this?
Part# 210 352 1005 - '98 wagon 'camber strut/control arm' chassis to top of knuckle.
The numbers:
A 210 352 10 05 my wagon's arm in photo
Old Apr 21, 2022 | 12:04 PM
Overheated's Avatar
Originally Posted by Plutoe
yea biff you ordered the wrong part, wake up you should have gone here first---------Mercedes-Benz Electronic Spare Parts Catalogue Online
Ooooh...my security setting won't allow me to open your site.
So, it resolved (sort of) that I found the attached photo with the explanation and correct part#. The "kit" is being sold on a few of our favorite websites as a fit for the wagon, but doesn't take into account the different arms designated between sedan and wagon. The wagon arm is peuliarly curved, and made of aluminum, while the sedan arm is straight steel. 2nd and 3rd arm in the photo. After this sorted out, the CA Meyle rep found it at FCP https://www.fcpeuro.com/products/mer...06#description
Old Apr 24, 2022 | 11:35 AM
CanuckMerc's Avatar
2001 E320 4Matic
I've just finished rebuilding my 2001 wagon. The problem you're having is that many of the parts suppliers (including the best in my opinion-AutohauzAZ) typically do not have a coding or cataloguing for the difference between a wagon AWD and a sedan AWD. The difference is in a few of the parts in the rear. Brake shields, LCA's etc. What you need to do is go on EBAY and buy yourself a 20 dollar WIS/ASRA for that year car. Look for 1998 Mercedes Wagon WIS/ASRA. What you'll get is the catalogue on that car for repair procedures and the parts catalogue. Then you have no problems getting the proper parts number.
Also another advice for you, based on my experience thus far of repairing everything on my car (I live an hour out of the city so I have to wrench my stuff) including replacing the front end suspension. Make friends with your local Mercedes parts department. They'll give you the same prices you get at AutoHauzAZ if they know you're continuing to buy through them and the parts are Mercedes original. I've gone this route after about the third or fourth wrong part (yes I had the proper parts numbers but they'll still screw up and send you sedan parts).
Currently I'm still working my job, as I had to replace the nitrogen sphere's and doing that job I broke the levelling valve, twice and screwed up the hydraulic lines having to replace them as a result. Words of advice here if you ever get into that job: mark paint your lines before you cut. Also hydraulic fittings are screwed in by hand only and tightened by flare wrench only at the end. Ugh. ugy ugh. Hope this all helps.
