1997 E300D Trans Rebuild: Valve Body/TCM Mismatch?
Old Dec 1, 2022 | 02:16 PM
motrengaw's Avatar
1997 E300D
After being stranded with a P0730 code ("incorrect gear ratio) and being shown significant metal in the pan, I had my 722.6 transmission re-built by a local shop. The rebuild transmission has some odd behavior, which the shop attributes to a mismatch between a new valve body and the old TCM (Transmission Control Module?).
The behaviors:
  • 3-5 sec delay before dropping into forward or backward gear progression.
  • Reluctance to upshift to higher (3,4,5) gears in hard (freeway onramp) acceleration. Counter-intuitively, if I pull back a bit on the accelerator, the upshifts will occur. If I just keep the pedal down (but not enough to engage the downshift switch) the engine simply races and acceleration fades as I move beyond above the power band.
  • Upon stiff braking, or sometimes a quick lift off the accelerator, hard downshift bumps from 2->1.
The rebuilder (the shop sent the work out-of-house) maintains that the original valve body is no longer being manufactured, and that a new valve body requires a new TCM to manage the shift points properly. Does this sound right to the forum?
NB: I may be confusing TCM and TCP (control plate), but I don't think so. I'm out of my limited depth though. ;-)
Thanks for any light you all can shed. Particularly user MAVA in Sacto. (I'm in Oakland).
