Upgrade Wheel/Tire !!HELP!!
i have a 1999 E320 and i'm going to upgrade the stock 16's to these:
Size (front) 18x8.5
Size (rear) 18x8.5
Offset 37MM
Bolt Pattern 5X112MM
i was juss wondering wat size tires would be good so no rubbing or ne other problem will occur?
thanks
I beleive it would be close on stock height of a regular E but it should work- especially when you guys have them set higher than in Asia and Europe in the first place. In any case, I personally don't prefer to have anything more than 235 up front to maintain agility in the turning (and save a bit on gas
!), at least for non-AMGs.
18X8.0 et25 thru et34
18X8.5 et25 thru et28
Here is a offset calculator:
http://www.mindspring.com/~toy4two/offset.html
My setup was only a 4mm change - from 18X8 et31 to 18X8 et35.
1) If you went from 8" to 8.5" wide wheels, that would take it bring it in 0.25"= approx. 6mm (1/4" each side);and
2) With ET35, you bring it back out 4mm EDIT: take it in by a further 4mm!
Net: 2mm further in (i.e. less than 4mm), hence that should work in oofie910's case. EDIT: 10mm further IN! (but definitely worked for me on 235's - see below)
In Omair05's case:
1) 8.5" ===> 6mm in; add
2) ET37 ====> 6mm in
Net: 12mm further in.......too far in!
But with 235's as opposed to 245, that brings it in 5mm (on each side) ====> net 5mm in i.e. > 4mm, won't work (based on Kev's info).
But that's all assuming:
1) The height of his car is the same as E55 (which it is not)
2) The E55 nut part is exactly the same on his regular E (is it Kev?)
However, it also depends on the shoulder design of the tire since different tires have different shoulder widths (I think Kev taught me that a while back
). Based on the above, 245 MAY not work for Omair05 but on stock height, he might be able to get away with it. 235 is a safer bet, whilst 225 will definitely work but too stretched, at least for my liking, and the speedo will be off.
Since there's a few uncertainties, I would suggest trying the 245 first (if 245 is what you insist on). Then if it does rub, use a 5-10mm spacer to space out the front wheels (but that will make the front's appear too far out compared to the rears, so you might have to space out the rears as well).
I trust you will agree with this analysis Kev?
https://mbworld.org/forums/e-class-w210/85895-w210-suspension-help.html
https://mbworld.org/forums/showthread.php?t=85895
