Headlight Bulb Replacement & Poor Performing Headlights
I have a Mercedez Benz E240 W210 2000 and I have two issues that I am looking for help with. Keep in mind my location is Australia if that helps
Issue 01 - The driver side (right hand side) headlights are not working. Do I assume the fix is just buying a new bulb for each light and that is all? Can I do any testing myself (I don't have any diagnostic tools or machines and prefer not pay someone either)
Issue 02 - Both headlights right and left have very poor light performance. What I mean by this is they are not very bright and it seems as if the plastic light covers (is that what it's called?) are getting old/blocking most of the light that the bulb is illuminating. Can I clean/polish these or need to buy replacements?
Headlights are not working (bulb need replacing?) Dial to turn on headlights is definitely switched to on.
Headlights are not very bright and seems the colour is slightly off and covers are blocking the light from coming through.
Thanks kindly.
Then why I'm not telling you? Corrupt/cause could be very simple, but there's so many factors involve. As you said, could be the bulb, or could be the wiring, could be................. You got the idea,
So do a search, look for it yourself and if you can't find or don't understand, come back and ask the question. You'll get much more help that way.
Removing the oxidation takes elbow grease and makes a little mess, but mine turned out great. Find yourself a video such as
Shortcuts like toothpaste and WD40 are BS. Put in the work and you'll get a great result.
This is 2 years since I redid mine.
