Codes P0107x2 P0173 P0302 P0130 P0100 2000 E430
P0107 x2
P0173
I have visually checked vacuum lines. Replaced all the valve cover vent rubber pipes that were very brittle. I replaced the brake booster hose. Replaced the complete air intake. Issue still remains. Result I'm out $225 in parts. In all honesty the parts needed replaced due to age.
P0173
I replaced 16 spark plugs, wires and coil pack for cylinder 2. Problem persisted. I replaced all 8 injectors and injector O rings. Problem went away for a while. $440
P0100
I replaced the MAF with an original Bosch unit. No change. $130
P0130
This one recently came on. O2 Circuit Bank 1 Circuit 1.
So almost $800 into it and no change.
The car has a slightly rough idle. When I put it in D it shakes off the line, same thing in R. After about 2800 rpm's it smooths out and no hesitation.
Sometimes I switch the engine off and then restart it and then it runs smoother and no more initial jerking off line at loose rpm's.
Any thiughts?
