How can I tell for sure if my transmission is going through all five gears
Old Oct 18, 2024 | 10:04 AM
Benrocks$Benz's Avatar
1998 e320 4matic
I've been having a hard time telling whether or not fifth gear is engaging. A couple months ago when the freeway was clear at night I was able to take the thing up to 123 no problem. I didn't even realize I was going that fast until I looked down at the speedometer. The car didn't vibrate or shut her at all. It was smooth it was quiet it was fast. Now I was trying to gun it down the freeway and today I noticed that pushing up towards 100 it seemed like it might have been struggling a little bit. I'm wondering if I'm no longer shifting into 5th gear because I've heard that sometimes is a problem with these cars but I don't know how to tell for sure. What kind of code reader can I hook up to see the gears changing if any? Where should I start troubleshooting? Sorry if there is already a more relevant sticky for this. I looked but I did not see anything.
Old Oct 18, 2024 | 12:41 PM
raymond g-'s Avatar
99 E320
I would have figured that the tachometer provides this clue....or am I misunderstanding something here?
Old Oct 18, 2024 | 02:36 PM
ilove190evo's Avatar
2000 E320
Shift it manually? Can it be that easy?
How fast your car goes, it all depending on condition the car is/are in, such as ambient temperature, road condition, uphill, downhill, flat road, etc etc.............................
Lastly, scan your car. Make sure you don't have any code, such as bad coil or trans problem.
Old Oct 19, 2024 | 09:14 PM
1998 e320 4matic
Guess you're right. I should I think go through all gears. I think I can hear them going up to four and even 5th gear. What should my RPM's look like when I'm going 90 in a 4matic 1998 E320. I thought that if there is a definitive answer for this it might give some clues. However I was going to see if I could get it up to 90 or 80 and then when I have it in drive click over to the left and downshift into fourth and if I can feel it go down into fourth and then click back over to drive which would be 5th then that would give me the answer that I still have fifth correct?
Old Oct 21, 2024 | 10:48 PM
raymond g-'s Avatar
99 E320
The RPMs aren't gospel (if I remember correctly) because it varies depending on engine temperature. e.g. the transmission logic keeps the revs high(er) when the engine is cold as this helps warm the engine a little quicker when it is first started. But I think if you induce a FIRM acceleration from a standing start the RPM will drop (uhm, I'm guessing) 500 rpm-ish each time the auto shifting occurs.
Another reason why providing a definite RPM number per gear isn't realistic is that the adaptive transmission varies depending on the driving habit of each driver. It will 'adapt' and shift at lower RPMs for lead footers ....and shift at a higher RPM for grandmothers (and me).
