Changing Rims - Strange Noise !
I was given a set of E430 rims (OEM RIMS) with blizzak's mounted on them
which I attemped to mount earlier this month.
The Issue :
When I mounted all the Rims (e430 rims w/Blizzak) the car did not want to move, It acted like the parking brake was stuck (it wasn't) I didnt force it
feeling something was wrong ??? I did notice that the little it did back up i made a clicking noise from the rear wheel area?
Question: Are the lug bolts too long? I should be able to mount these rims ??
right?
Thanks any help would be appreciated!
Henry
If the wheel came off a W210 E430, there is no reason why you can't use it on your car, like AMG wheels will fit regular cars- you just need a different bolt.
as whitey has eloquently explanied earlier..........
