Ride height thoughts
Old Sep 5, 2025 | 02:15 PM
broham's Avatar
A4
Hey all, Finally finished my suspension refresh, went with eibach/bilstien setup..pads are #2 on all four corners. This pic is fresh off the jacks, needs alignment, but I was already thinking of going up in the front some more, and down in rear. Ill likely just drive it for a bit and see how it settles though before I get back under it. Opinions? Ty!
Old Sep 5, 2025 | 03:08 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Up in the front a bit more. Back looks good to me. The rear of your car is still one step lower than my W210 E55. Lower can look cool but it really screws with the camber and suspension response.
Since I have both, to me, the W211 looks better raked (front lower than back). The W210 looks better level front to rear so it looks more like a "Russian Mafia Staff Car".
Old Sep 5, 2025 | 09:45 PM
ilove190evo's Avatar
2000 E320
x2 on that. Not the ssme car, but when I had my Lincoln LS, I had almost the same look but I had to change the front to higher springs. Wait until you need to go under the building for parking or going up on a really steep ramp. Not to mention the speed bumps. But if you're in a area without any of these or not planning to go anywhere near these, should be OK. But our roads, no matter where you live, are not the same as road 10 years ago. What I mean is there's so many more pot holes...............
Old Sep 8, 2025 | 11:58 AM
illest's Avatar
w210 AMG or S213
Looks good
I used #2 pads in the front and #1 in the rear to get mine close to level.
Old Sep 8, 2025 | 12:50 PM
broham's Avatar
A4
Originally Posted by illest
Looks good
Looks good, although maybe a tad too low for me personally. Do you have any rubbing in the front? Mine is on eibach springs now.
Old Sep 9, 2025 | 07:46 AM
illest's Avatar
w210 AMG or S213
I get rubbing if I hit a bump in a tight turn but nothing other than that. In the pic in my sig I had #1 in the front but I have since switched to #2 or #3 (cant remember) to prevent bacon fenders. Also I was getting some rubbing from running a set a 4 rear monoblocks instead of the normal staggered setup.
Old Sep 9, 2025 | 07:54 AM
illest's Avatar
w210 AMG or S213
Rubbing
Old Sep 9, 2025 | 12:20 PM
broham's Avatar
A4
Rubbing
alright, so this is with the #1 pad in front im assuming?
Old Sep 9, 2025 | 01:03 PM
illest's Avatar
w210 AMG or S213
yes, #1 pads, vogtland springs and rear monos in the front with 5mm spacers.
Old Sep 12, 2025 | 01:28 AM
Tall Giraffe's Avatar
2001 E55 OMG
Rubbing
Im running your exact previous set up (2F 1R pad) Vogt, B8 but with 31 ET 8.5" upfront. Your rubbing may come from those lower control arms. I was rubbing/scuffing driver side fenders especially with left hand turns but that went away after new lower control arms. I thought the gap between the tire and fender were uneven and people would say it looked like I hit a curb.
I did install KMAC and rear arms for camber adjustment and I am with in spec. I am noticing the aggressive drop is wearing out my bushings and links upfront much quicker.
Old Sep 12, 2025 | 09:40 PM
illest's Avatar
w210 AMG or S213
@Tall Giraffe good point when I swapped out the spring pads I also did new control arms and from shocks.
Old Sep 13, 2025 | 01:07 AM
raymond g-'s Avatar
99 E320
mine with Eibach / Bilstein Sport, 2F and 1R pads. It has settled a bit more so I am going to raise it a few mm both ends next month. Always keeping my eye out for monoblocks, too
Old Sep 13, 2025 | 05:13 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Are those W211 E55 wheels on your car? If so, the W211 uses 14mm lug bolts, the W210 uses 12mm lug bolts. W211 wheels on a W210 will result in broken lug bolts and wheels coming off the car
Old Sep 13, 2025 | 06:34 PM
raymond g-'s Avatar
99 E320
I'm using 12mm dia bolts with R14 ball seat to match the wheels.
