battery dead
Old Jan 26, 2005 | 02:21 PM
2quik's Avatar
battery dead
Whats best way to keep battery charged in winter. I dont use my car often, due to snowy and icy conditions, but seems battery dies even though i start it every week , and drive it every 2 weeks, I was thinking of a trickle charger. ? any ideas anyone
Old Jan 26, 2005 | 02:44 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
2 weeks witout driving should not be a problem. Perhaps your battery is on its last legs. If its over 4 years old replace it. There are also battery devices that attach with clamps available that maintain a full charge when plugged in.
Old Jan 26, 2005 | 02:46 PM
E320Star's Avatar
2000 E320 Sedan
if the bat is 4 yr or older, replace the dead battery. How old is you car? what u drive? How old the battery?
Old Jan 26, 2005 | 03:10 PM
2quik's Avatar
battery is 6 months old, its very cold here, its a 2001 e 430sport, where can i get a good battery charger/maintainer?
Old Jan 26, 2005 | 09:00 PM
Paxfobiscum's Avatar
Chevrolet Chevette, Ford Pinto, Pontiac Aztek, Trabant, Yugo GV (and all the worst cars ever built)
Just for info... my car is about seven years old and the battery that came with the car when it was first purchased has never ever ever been replaced. It takes me 0.5 seconds to start the car after not using it for three weeks. I live in cold and freezing NYC. There is no need to replace your battery unless you need to replace your battery.
Old Jan 26, 2005 | 09:36 PM
JLLG's Avatar
1997 E320 2000 ML430
Make sure that no interior lights are left on. Do you have anything plugged to an accessory plug that may drain the battery. If none of the above, either something is drawing current from your battery or your battery is bad. New batteries can be bad. Does anyone know how to perform a test to see if something is using battery when it should not? I realize minimal draw is required for various components but that stuff should run for at least one month and still start your car.
