shift councel
Old Jan 29, 2005 | 12:16 PM
Michael Pietrzy's Avatar
1997 E 420
Talking shift councel
anyone know how to romove shift councel or shift cover? spilled drink on need to open up and dry and clean all switches. windows go up & down by themselves shift not working rt. :
Old Jan 29, 2005 | 06:41 PM
The Godfather's Avatar
4 wheeled car.
Console is the proper term. Anyway, you remove the gearknob, then pull up on the black trim ring around the shifter. Once you do that, open your ashtray and grab onto the wood panel (where your shifter, windows button etc are) and pull up. It just snap off. Then pull from the back and it comes right off. You'llre figure it out.
Old Jan 30, 2005 | 08:54 AM
Whitey's Avatar
98 W210 Advantgarde
LOL, I couldn't work out what the title meant! Anyways, here's a little vid to show you exactly what Doc meant (except it tells you to pull from the cupholder, same idea)...right click and "save as" if left clicking doesn't work.
http://www.edsoto.com/w210/media/w210%20f.mpg
However, taking all that apart might not be enough to get into the actual shift mechanism which is a separate box underneath.......good luck.
Old Feb 1, 2005 | 10:17 PM
1997 E 420
console
Thanks for the help. took it out, cleaned it up all works find.
