W210 Wood and Polishing it
Robert
I suggest this because I had my center console apart enough to see the edge of the shift surround. It appears to be a laminated metal glued onto a plastic frame. The edge of the flip-up door on the ashtray also suggests it to be something other than wood.
I could be wrong... but I'm never in doubt.
Robert
Most W210s are Burl wood..Unless its a AMG E55 or 02 W210..They have Black Birds eye maple
I Use Meguiars Plastx for polishing out scratches on the wood..Works Great!
You could use car wax, but make sure you dont get it on the rest of the interior.
1 - Less effort, as you simply throw out the old one.
2 - A guaranteed matching color finish as compared to the 'trial-and-error" method.
3 _ A guaranteed sheen finish (again as compared to the 'trial-and error" method.
I suppose if you were to remove and refinish all of the wood it wouldn't need to have the exact finish as OEM, but let me tell you.....
It will be extremely difficult for a consumer/DIY-type to obtain and apply a finish coat that is comparable in quality, durability, and finish to OEM.
Most of the available OTC (over the counter) products will not even come close to surviving the UV rays or temperature cycling that these parts endure. Temperatures inside a car can vary from 20 below 0°F in winter to over 140°F in summer.
I work at a high-end cabinet shop and I will not even attempt to refinish one of these parts myself. Aside from the finishing issues, the wood veneer itself (if it is even really wood) is paper-thin (less than 1/64th of an inch!) and removing the OEM clearcoat without damaging the veneer surface will prove troublesome if not impossible for most consumers.
If it is a really deep scratch, replace the part and take better care of it than what was offered to the original.
http://interior.articles.mbz.org/wood/
There are several more links on the web. I agree that most owner should not even attempt a refinish. One would just have to compare the costs of refinish versus new. Has anyone priced new wood trim pieces?
