A whirling thud sound at 40 to 60 mph??
It's been that way for 2 yrs. I thought it was a bad alignment or bend rims. I had the car aligned & rims changed many months ago.
Could it be in the transmission?
The car handles fine & always checks out ok when in the shop for usual maintenance. I play music a lot so a usually don't hear it & I forget about it. How can I eliminate this sound?
Going to pick up my E from the shop today after a R&R of a rear wheel bearing. I had a seized bearing and made a sort of clack clack sound.
Heard other cars with a bad bearing and made a different type noise, more like what you described.
good luck,
-travis
Maybe I'm being picky?
Do you have a pic of your car. I'm thinking of getting the Eibach spings & shocks w/dampeners.
Did you ever find out where the nosie was coming from?
Hi or low frequency?
Speed or RPM dependant?
On acceleration or deceleration?
Once you hear it, if you put the car in N: Is it still there?
Do you "feel" the noise?
Is your exhaust/muffler in good condition?
Depending on the answers could be, among other things:
Roller bearings
Flex discs
Differential mounts
Motor mounts
Trans mounts
Shaft balance or central bearing
Tires/wheels
Rotors
Exhaust hole
